Old 04-21-2009, 09:37   #1 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
Lg kp199 dead by infinity box
I have kp199 lg set here just for language change and after write the other firmware from infinity support its dead now. I have tried both flash files from infinity support and also try whole erase chipset option but set is not getting on again tell me what to do here is log of this set
COM4 [VCP1] selected
module v2.70
Device: LG-KP199
Checking data, wait...
Action: write NOR flash
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:4AAE:591C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:FFFFFF00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: LG-KP199__ffs...
file saved: C:\Program Files\InfinityBox\MModule\LG-KP199__ffs_20090422-002856.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 404 sec
Remove/Install battery now !
Thanks in Advance
Z.K
The Following User Says Thank You to zubairok For This Useful Post:
Old 04-21-2009, 10:14   #2 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
Originally Posted by indikait View Post
Try to repaire furious box
i don't have furious box
Old 04-21-2009, 12:41   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
@indikait
Your message with stupid advice was deleted, here is Infinity-Box support forum. If you want to talk about anything other you must write your messages in correct thread.
If you have no good advice it's better to be silent than write bad advices.
@zubairok
Charge batetry completely with external power supply
Flash phone with any firmware from support area.
Make "format ffs"
Press and HOLD phone "Power" button for about 1 min to make phone powered-on after flash/format.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 04-22-2009, 06:53   #4 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
Originally Posted by InfinitySupport View Post
@indikait
@zubairok
Make "format ffs"
Thanks Sir My Problem solved with writing IMEI again and I know the Infinity team is best in the world and I don't beleive on any other box I use only Infinity box for all LG and China
Thanks Again for your quick help
Z.K MOBILES PAK
Old 07-02-2009, 19:10   #5 (permalink)
Member: 477510
Thanks Meter: 31
Lightbulb
Hi All Form
plz help me
lg kp 199 after flash daed with this firwmare file :KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M
Note:FLASHING INF?COM6 [VCP0] selected
module v2.58
Device: LG-KP199
"smart write" active
"format ffs" active
write: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 0031:3689:1109
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
Initialize Done
Set baud ...
115200
Set baud Done
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is damaged, recalculation required
identification#1 detection finished
device-id: 937BB7B8
identification#1 protocol ver: 04
ver. sw 1: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN
ver. sw 2: 7S7339SA00-002-R1C, 65657A3B
ffs offset/size: 00E00000/00200000
reading: eeprom[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN]_20090702-214420.B0E.bin
Write ...
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 1607 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 07-02-2009, 19:15   #6 (permalink)
Member: 477510
Thanks Meter: 31
Hi All Form
plz help me
Note:FLASHING INF?
COM6[VCP0] selected
module v2.58
Device: LG-KP199
"format ffs" active
write: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
device-id: 937BB7B8
Write ...
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
formatting...
Finalization Done
Old 07-03-2009, 00:29   #7 (permalink)
Member: 788720
Sonork: 100.1617957
Thanks Meter: 33
Dead set on by writing imei......sooo strange...anything can happen in gsmworld
Old 07-03-2009, 00:48   #8 (permalink)
fethi's Avatar
Member: 57836
Thanks Meter: 47
i never killed a phone with infinity software
i did with other tools
so if any phone dead by infinty, must be sone thing wrong happint, so chek again
best reguards
Old 08-26-2009, 09:11   #9 (permalink)
rizoo's Avatar
Member: 375590
Thanks Meter: 45
My kp 199 dead after flash i just want to change language packge.i tried different ver but mobile set can't be on, i also format ffs and change imei,but nothing .plz infinity team help me.
Old 08-26-2009, 09:25   #10 (permalink)
Member: 130995
@rizoo
Post answers for all questions:
What MModule version you have used ?
Do you see any errors during flash process ?
Did you checked battery voltage ?
Old 08-26-2009, 11:18   #11 (permalink)
rizoo's Avatar
Member: 375590
Thanks Meter: 45
yes sir,
i have v 2.82 and there is no error during flash , all process done successfully and i'm using Digital Voltage Supply (with 4.42 Volts) plz help me'
and thanks so much for your Quick Reply.
Old 08-26-2009, 13:51   #12 (permalink)
Member: 130995
Hello,
1. download latest MModule 2.84
2. try to flash phone with different flash files from support area
3. make "format ffs" in "complete" mode after flashing
Old 08-28-2009, 20:27   #13 (permalink)
rizoo's Avatar
Member: 375590
Thanks Meter: 45
Now i'm downloading MMmodule ver 2.84,and also write all firmware from downloading infinity support area.format ffs.but my kp199 can't power on.i'm not using cable.i'm using direct RX and TX from PCB.all process done successfuly.and my set was working ok before flashing.can u help me infinity Team?
Old 08-29-2009, 09:29   #14 (permalink)
Member: 130995
1. What was original phone firmware version ?
2. What is your phone battery voltage ?
3. Did you tried to press and HOLD phone "power" button for a long time to make it powered-on ?
Old 09-03-2009, 11:50   #15 (permalink)
Member: 321173
Thanks infinety team after write imei my phone is ok
is lg km380 supported by infinity box? hyber_99 Infinity-Box 3 08-07-2009 02:07
lg 195 repair by infinity box navnath randive LG 1 08-01-2009 19:55
kg290 got dead by infinity box. Umair Rashid Infinity-Box 9 02-09-2009 08:14
Lg Kg245 Kiled by Infinity-Box Revived by KhalIman Infinity-Box 24 01-09-2009 15:50
C2200 Dead By Infinity Box alamgarh Infinity-Box 4 02-22-2008 10:02
Page generated in 0.46989 seconds with 8 queries
