LG KP220 Hang on LG Logo LG KP220 Hang on LG Logo. I try to Format and many flash File but phone still on Lg logo and Off. |
You need to open phone and check is it exist NAND flash chip in this phone. If NAND chip exist you can use this method: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ LG-KG300_KG200_KG195_repair_freez_restart.txt Please, post here your results. |
problem solved with KG30:), KG200 CONSTANT BLINKING on LG logo:) Thanks infinity team |
here is log COM5 [VCP0] selected module v3.11 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6219:8B02:8B01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (115200)... done interesting cpu type found: 6219:8B02:8B01 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7338SA00-002-R1B detect NOR info... number of areas to read: 1 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA00-002-R1B.BIN project-id: 7S7338SA00-002-R1B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 2CFBFB2F4B9BEE4AE7DCBC253ECD15E8 warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 1 min 53 sec Remove/Install battery now ! |
This is log with erase whole flash chip Again same problem COM5 [VCP0] selected module v3.11 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6219:8B02:8B01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (115200)... done interesting cpu type found: 6219:8B02:8B01 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7338SA00-002-R1B detect NOR info... number of areas to read: 1 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA00-002-R1B.BIN project-id: 7S7338SA00-002-R1B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... 00000000-03FFFFFF... Disconnect... done Finished, time used: 2 min 14 sec Remove/Install battery now ! |
what is "same" problem ? |
