Old 11-01-2009, 13:19   #1 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,903
LG KP220 Hang on LG Logo
LG KP220 Hang on LG Logo. I try to Format and many flash File but phone still on Lg logo and Off.
Old 11-02-2009, 16:56   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,386
Hello,
You need to open phone and check is it exist NAND flash chip in this phone.
If NAND chip exist you can use this method:
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ LG-KG300_KG200_KG195_repair_freez_restart.txt
Please, post here your results.
Old 11-02-2009, 18:28   #3 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 388
problem solved with KG30, KG200
CONSTANT BLINKING on LG logo
Thanks infinity team
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post:
Old 04-26-2010, 14:13   #4 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Originally Posted by InfinitySupport View Post
Hello,
I am facing same problem. Done as you said but same problem
here is log
COM5 [VCP0] selected
module v3.11
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.952.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6219:8B02:8B01
status: FF
bbchip bl ver: FE
NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_EXIST/00010000
NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B
chip size: 64Mb
page/spare size: 0800/0040
pages/block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00047000
external RAM [HW_RAM_SRAM, CS1] size: 00800000
done
Set baudrate (115200)...
done
interesting cpu type found: 6219:8B02:8B01
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/04000000
ffs size: 64Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: 7S7338SA00-002-R1B
detect NOR info...
number of areas to read: 1
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 04
sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA00-002-R1B.BIN
project-id: 7S7338SA00-002-R1B, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
rom info structure: 2nd [standard] generation
TCL-ID is absent
detect NAND info...
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
warning: incorrect header: 2CFBFB2F4B9BEE4AE7DCBC253ECD15E8
warning: can not detect header
nfi area detection finished: failed
warning: ffs can not be detected
TCL-ID detection...
===> done
Format (HW_STORAGE_NAND)...
Disconnect...
done
Finished, time used: 1 min 53 sec
Remove/Install battery now !
Old 04-26-2010, 14:24   #5 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
This is log with erase whole flash chip
Again same problem
module v3.11
Action: erase whole flash chip
Connect...
Connecting...
Booting...
CPU: 6219:8B02:8B01
status: FF
bbchip bl ver: FE
chip size: 16Mb
chip size: 64Mb
pages/block: 0040
bits i/o: 08
address cycles: 04
done
done
ram test...
testing...
ram test passed
detect ffs...
ffs size: 64Mb
detect sec ro...
detect NOR info...
TCL-ID detection...
rom info ver: 04
TCL-ID is absent
detect NAND info...
warning: header is empty: probably flash chip completely erased
TCL-ID detection...
===> done
00000000-03FFFFFF...
Disconnect...
done
Finished, time used: 2 min 14 sec
Old 04-26-2010, 15:01   #6 (permalink)
Member: 1043909
Thanks Meter: 52,087
what is "same" problem ?
Old 04-26-2010, 16:42   #7 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Old 04-26-2010, 20:11   #8 (permalink)
Member: 1043909
If "erase whole flash chip" operation can not helps you have to open phone and check it's hardware, it may be a hardware fault but not a software fault.
Lg Kp320 , hang on "kp320" logo on lcd screen. nakshatra Infinity-Box 6 03-21-2010 11:01
Lg U8500 hang on LG Logo cant be flashed alfox FuriousGold 2 11-19-2009 23:20
LG U830 hang on LG logo [Solving] villa_wency Z3X-Team Products 4 10-01-2009 16:56
LG KP500 HANG on LG... Just FLashing with Z3X LG!! bestncheap Z3X-Team Products 6 08-22-2009 17:16
LG C3380 hangs on startup logo ... harim_1981 Multi-Box 4 06-18-2008 18:09
Page generated in 0.35618 seconds with 8 queries
