Lg Kp220 Problem I have a LG KP220 which is come to me in fault only startup logo comes and hang.i try to format with the help of pinfinder pins selected manulay but not work. i try to find i select cable "L18B" and "cpu independent(autodetect)algorithm" here is logs software version: 1.14 cable type: 1x18 (L18B) platform: CPU independent (autodetect) algorithm searching adapter at COM7... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... detected baudrate: 115200 result: Rx:16 Tx:14 time required: 12 sec Power On ! it detects pinouts diffrents from given in soft.after detecting i format it but not connected.so plz tell me how i format it. |
Hello, Double check that phone connector is Ok. If you want to detect pinout for KP220 you must select AD CPU type. |
