Old 02-26-2009, 12:22   #1 (permalink)
Member: 563167
Thanks Meter: 39
LG KP235 unlock done 100%
COM7 [VCP0] selected
Device: LG-KP235
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
warning: wrong data size at 0x01002000, retry...
read error recovered
warning: wrong data size at 0x01002400, retry...
warning: wrong cs at 0x0100F400, retry...
current eeprom imei: 352127020254228
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352127020254228_LG-KP235_20090226-111810.B1E.bin
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 89 sec
Remove/Install battery now !
The Following User Says Thank You to cllins For This Useful Post:
Old 02-28-2009, 20:21   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Device: LG-KP235
Action: unlock
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Check flash Done
Check space...
current eeprom imei: 352127020xxx
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
LG KP235 unlock Svetli Infinity-Box 9 04-05-2015 14:03
LG KF 750 unlock done 100% Master Software SETool2 0 02-23-2010 15:53
Kp235 unlock done nadirghazi FuriousGold 1 12-08-2008 11:25
KP235 Unlock Done. ..::Angel::.. Infinity-Box 1 12-05-2008 18:02
lg kp235 unlock? karina23b FuriousGold 5 10-19-2008 12:11
Page generated in 0.15623 seconds with 9 queries
