Old 10-28-2008, 16:45   #1 (permalink)
Member: 295823
Thanks Meter: 7
LG kp235, unlock by infinity...
for reference purposes only..
here's the logs:
COM26 [VCP0] selected
Device: LG-KP235
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 3521270201DIABLO
file saved: C:\Program Files\InfinityBox\LGA\eeprom_3521270201DIABLO_LG-KP235_20081027-170240.B1E.bin
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 51 sec
Remove/Install battery now !
PINOUT:
1(GND)2(RX)3(TX).5(GND)..........15(GND)...18(GND)
connector above the board back of charging pin start from left facing you..
The Following User Says Thank You to alyann For This Useful Post:
Old 10-28-2008, 17:36   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
another lg kp235 unlock ok by infinity box genci titi 2002 Infinity-Box 3 04-02-2010 12:54
lg kp235 unlock by infinity very easy aleem26 Infinity-Box 1 11-18-2008 11:00
LG C1200 Unlock by INFINITY gravity06 Infinity-Box 1 10-13-2008 10:20
need lg cg225 unlock by infinity sayfulalam Infinity-Box 0 08-12-2008 09:40
<<< LG KG290 unlocked by Infinity >>> zeel_zeel Infinity-Box 1 07-28-2008 07:33
Page generated in 0.23464 seconds with 8 queries
