04-09-2011, 14:08 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | LG KP320 flash failed, now DEAD i have LG KP320 when power ON only hang and showing LG KP320 logo, and won't open up menu... i try to format ffs but cannot connect, i try to read flash, but it take long process so i press cancel, afterwards i flash using firmware from support download and get this results : COM18 [VCP0] selected module v3.55 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10a-ESA-XX-APR-17-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1A_En_Melayu_Indonesia_Vn_Th_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... converting data... done 0x01555800 bytes external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1A.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610AA00-001-R1D detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 424F4F544C4F41444552010056301035 warning: can not detect header nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D.BIN project-id: 7S7610AA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done nfi area detection... converting data... done 0x01555800 bytes external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1A.bin nfi area detection finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST error: last error: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST Disconnect... done Finished, time used: 1 min 26 sec Remove/Install battery now ! now i cannot power ON phone again, phone is now DEAD, can someone teach me how to revive this phone again? thx a lot |
04-10-2011, 08:51 | #4 (permalink) | |
Also, if your phone was "freez at startup" there is a big chance that it's a hardware problem. | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
