Old 03-20-2010, 09:03   #1 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
Lg Kp320 , hang on "kp320" logo on lcd screen.
HI
is this software problem or hardware :
I have tried with software wit diff. flash file given on support area.
here is soft. log ;
COM1 [VCP0] selected
module v3.23
Device: LG-KP320
Checking data, wait...
Action: write flash NAND
write: Firmware
KP320-00-V10e-404-XX-APR-18-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2K_En_Hindi.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
firmware patch (general #0)...
not required
firmware patch (sp-lock #1)...
not required
not required
nfi area detection...
external bootloader is not present
bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2K.bin
nfi area detection finished: Ok
"format ffs" active
interface: BROM_DLL_v3.936.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6229:8A02:8A02
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages/block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00020000
external RAM: absent
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: 7S7610IN00-001-R2K
detect NAND info...
number of areas to read: 1
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 04
sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2K.BIN
project-id: 7S7610IN00-001-R2K, 00000000
code offset: 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
startup code area #1 check...
startup code area #1 fixed
number of cores: 3
loading files...
number of areas: 3
done
write...
error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND
error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND
Disconnect...
done
Finished, time used: 1 min 42 sec
Remove/Install battery now !
Old 03-20-2010, 16:48   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,219
Hello,
Try to make "format ffs" in "complete" mode.
Also, be sure that you have at least 128 Mb free space at your HDD, this helps to avoid problems with flashing.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-21-2010, 06:50   #3 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
both tried but, same result.
any other way,
set was dropped on the floor.
Old 03-21-2010, 07:11   #4 (permalink)
Member: 416063
Thanks Meter: 27
my problem is same please help
Old 03-21-2010, 07:11   #5 (permalink)
Member: 416063
Thanks Meter: 27
write...
Disconnect...
done
Old 03-21-2010, 10:01   #6 (permalink)
Member: 1043909
Thanks Meter: 50,167
You must repair phone hardware !
If somebody drop something on the floor it is impossible to damage phone software but it's possible to damage hardware only.
so you must open phone and check it's hardware, f.e. rehot/reball CPU and flash chip etc.
Old 03-21-2010, 10:01   #7 (permalink)
Member: 1043909
Same answer for the same problem: Lg Kp320 , hang on "kp320" logo on lcd screen.
U600 hang on samsung logo on start up, done.. fonERICKS Z3X-Team Products 2 02-10-2014 15:41
Lg u880 hangs with 3 logo Unicom LG 0 03-24-2010 07:53
m200 hang on m200 logo on screen rohit50 NSPRO 5 07-23-2009 11:38
LG U880 hang with 3 logo Unicom LG 4 01-01-2009 12:44
LG U880c hang in 3G Logo ASHRIFF LG 1 03-03-2007 00:23
Page generated in 0.27114 seconds with 8 queries
