09-21-2008, 15:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | LG KP320 lock code can this be supported? br |
09-22-2008, 06:53 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Aqua Project Age: 47
Member: 115242 Status: Offline Sonork: 100.1581364 Thanks Meter: 1,638 | very easy way to check supported models by infinty box check always sticky thread http:///vbb/showthread.php?t=266144 Anyway this model not supported by infinity box i hope soon will be supported ....... Br. |
The Following User Says Thank You to Miftahudin For This Useful Post: |
09-22-2008, 15:48 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What is this phone bottom connector type ? Probably we can support this phone if you will find Rx/Tx and if you will be able to make some tests. |
09-22-2008, 20:47 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, use KE500 cable run ChineseMiracle software select model "MT6228" read full flash send flash backup file to [email protected] (or upload files at rapidshare.com) |
09-23-2008, 09:08 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thank you ! Please, try to make "read codes" operation now. Waiting for your results. |
09-24-2008, 07:13 | #15 (permalink) |
Member: 51453 Status: Offline Thanks Meter: 729 | still the same. COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Autodetect 6228, 6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6229:8A02:8A02]... CPU: MT6229 high speed boot enabled chip: 0031:200E:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 95 sec Remove/Install battery now ! been trying many times but i always get that error.what should do next? thanks br |
samsung A886 locked in rogers when will this be supported? | marc_andrei | Z3X-Team Products | 6 | 02-14-2010 14:48 |
LG KP320 security code Removed!!!!! | misbah123 | Infinity-Box | 5 | 01-06-2010 05:35 |
LG kp320 lock Code | unlock trigger | VygisToolbox | 6 | 01-03-2009 14:44 |
LG KP320 security code | asad_nomy7 | Infinity-Box | 1 | 11-12-2008 17:19 |
5310 can this be supported for unlock? | shawgsm | Gsmfather The Wholesale Unlocking Database | 3 | 10-01-2008 16:10 |
