04-07-2009, 13:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | nokia copy 5220....need help case: set nokia 5220 comes in the problem tht it was not opening the menu. after format it can open the menu. after ormat it was on emergency call. duing this state with out sim it cn make call 112. i epaired imei. still emergency. i formt the whole chip. set was dead after that. by writing full back and eeprom set was on but same situation(its imei number is made ok, it can call with out simm to 112 but with emergency. an important thing from menu..setting. phone setting..the option network selection has disappererd. this option is no where in the phone. phone contin the flash file RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN] the pin out are also attached to be added for future pin out updtes. is there any way to make it working. br hamid |
The Following User Says Thank You to biochemistali For This Useful Post: |
04-07-2009, 13:58 | #2 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | the flash log is COM16 [Serial2] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:B403:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: 90613C6C identification#1 protocol ver: 04 ver. sw 1: RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN ver. sw 2: A510_SM_K5L2731_ILI9221_V01, 95366C84 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . detect device identification#2 finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.90613C6C.[RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN_7B93C96A].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.90613C6C._RHY2 5_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_ILI922 1_V01.BIN_7B93C96A_.rpl security area (code #1) backup loaded security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 593 sec Remove/Install battery now ! |
04-20-2009, 07:54 | #3 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | 5220 file avai;able if neede i got full back up 5220 from a working phone available if needed. complete description of file is RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN] br hamid |
04-20-2009, 08:29 | #4 (permalink) | |
Please, send this full flash backup to [email protected] Thank you ! | |
siemens CX75 cant copy anything... need help | haloman | Siemens Hardware Repair Area | 2 | 03-13-2006 09:09 |
nokia 3100, i need help!!! | shurubelul | UFS2 + UFS3-Tornadoflasher | 2 | 08-02-2005 14:30 |
Nokia 3220 flashing..need help! | david69 | Griffin | 0 | 02-13-2005 21:01 |
NOKIA 7110 SOFTWARE, NEED HELP !!PLZ. | PopeY | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-01-2000 07:56 |
