LG me770d unlck by infinity here the logs cable:kg800 i use me770 COM6 [VCP0] selected module v1.60 Device: LG-ME770 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-static_20090113-125856.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-static2_20090113-125857.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-security_35030526000000100_20090113-125859.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-complete_35030526000000100_20090113-125902.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 0191 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 25 sec Remove/Install battery now ! hope more LG support infinity team your the best |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
