Old 01-14-2009, 00:55   #1 (permalink)
Member: 683463
LG me770d unlck by infinity
here the logs
cable:kg800
i use me770
COM6 [VCP0] selected
module v1.60
Device: LG-ME770
Checking data, wait...
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0089:88B0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-static_20090113-125856.B1E.bin
reading eeprom-static2...
file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-static2_20090113-125857.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading eeprom-security_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-security_35030526000000100_20090113-125859.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-ME770_eeprom-complete_35030526000000100_20090113-125902.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 0191
Done
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 25 sec
Remove/Install battery now !
hope more LG support infinity team your the best
The Following User Says Thank You to yunaced For This Useful Post:
Old 01-14-2009, 19:08   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Lg Kg245 Kiled by Infinity-Box Revived by KhalIman Infinity-Box 24 01-09-2009 14:50
need lg cg225 unlock by infinity sayfulalam Infinity-Box 0 08-12-2008 08:40
<<< LG KG290 unlocked by Infinity >>> zeel_zeel Infinity-Box 1 07-28-2008 06:33
Lg Kg275 Done By Infinity...............100% /ARIF/ Various 1 12-26-2007 00:42
LG KG290 supported by Infinity? fingusio Infinity-Box 2 12-20-2007 09:08
Page generated in 0.22363 seconds with 11 queries
