LG MG110 imei repair Hi Support, I´ve just repaired imei for the model on title (the phone was blacklisted, thus it detected nets, but did not register sims) and now it goes on without registering sim, more, it goes on showing original (eeprom) imei by pushing *#06# (imei sv). Can you solve this problem?....here you have the log: COM4 [VCP0] selected module v1.39 Device: LG-MG110 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 012006004147222 current otp imei: 011006004147728 file saved: C:\Archivos de programa\InfinityBox\LGA\eeprom_012006004147222_LG-MG110_20100418-164500.B1E.bin ........ version: 722-07V10a54MG110aP40FL Check flash Done Check space ... current eeprom imei: 012006004147222 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 462 sec Remove/Install battery now ! BR |
