05-02-2008, 14:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | LG-MG110a problem to unlock COM4 [VCP0] selected Device: LG MG110 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... warning: wrong data size at 0x01001C00, retry... error: too many retries during read operation ........ version: 734-04V10b58MG110aP40FL Check flash Done Check space... Check space Fail Finished, time used: 45 sec Remove/Install battery now ! Any idea about it, thank you very much PS: using the canle AT106 7050 |
05-06-2008, 17:30 | #6 (permalink) |
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | It was a kind of phrase to make refrencia I was unable to unlock the log show me the same warning in which I explained in my first post on this topic. I offer my apologies for not having explained and / or expressed well |
05-06-2008, 20:07 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @hvalero2001 please, double check your cable or use another cable. if you have "the same" problem this means that communication errors exist, it may be a result of bad cable. if problem is not exactly "the same" (as per my many years experience explanation like "the same promlem" is just a words without any real explanation) it's better to explain what is the problem exactly. |
mg110a how to unlock? | bachatia | VygisToolbox | 1 | 06-04-2008 22:21 |
LG MG110a dead by unlocking | Panthereitor | ULT PRO | 1 | 12-04-2007 01:37 |
problem to unlock a lg ku450 !! | humbedj | Easy-Unlocker | 1 | 09-18-2007 12:04 |
lg kg225 problem to unlock | jcosta | Infinity-Box | 2 | 04-10-2007 15:09 |
problem to unlock lg C1100 | adrian_tabajara | LG | 1 | 12-19-2005 16:55 |
