10-22-2012, 23:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: ((Gsm-Doctor))... Posts: 3,244 Age: 45
Member: 209093 Status: Offline Thanks Meter: 154 | Evertek FD10 MT6235B Dead after format ffs i tried with safe mode but no luck..! then i format with whole flash chip.. = phone dead.. and can't find flash file on support.. plzz help.. here log.. Code: ==== [22/10/2012 13:18:32] ==== COM26 [VCP0] selected module v4.40 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR chip is not detected NAND chip is not detected Repeat operation, Press and HOLD Power button more long time ! internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 07D4:S_BROM_DOWNLOAD_DA_FAIL error: last error: 07D4:S_BROM_DOWNLOAD_DA_FAIL Disconnect... done Finished, time used: 12 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [22/10/2012 13:18:49] ==== COM26 [VCP0] selected module v4.40 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8C00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: E580-02_MP_F1_TUNIS_V3 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E580-02_MP_F1_TUNIS_V3.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-02_MP_F1_TUNIS_V3.BIN project-id: E580-02_MP_F1_TUNIS_V3, 384CF181 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.4.40, database date: 18.09.2012): TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-02_MP_F1_TUNIS_V3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== Format... 00000000-03FFFFFF... Format done Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580-02_MP_F1_TUNIS_V3__system_log_20121022-132036.B4X.bin Finished, time used: 1 min 47 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? |
10-24-2012, 14:14 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Try to write this file saved in your pc- c:\InfinityBox\MModule\backup_security\TINNO35_09A _PCB01_GPRS_MT6235B_S01.E580-02_MP_F1_TUNIS_V3__system_log_20121022-132036.B4X.bin Br. |
