06-06-2011, 07:03 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: PAKISTAN
Member: 227428 Status: Offline Thanks Meter: 27 | LG S310 Unlock Problem COM5 [VCP3] selected module v3.92 Action: read unlock codes unlock method: read codes Model: LG-GS310 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: MAUI.09AW0944LGE_WISE_SP.W10.32 Version: ROSEMARY_HW 115 byte(s) read connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 205 byte(s) read reading data... 188 byte(s) read lock[1] code: - default lock[2] code: - default lock[3] code: - 1122 lock[4] code: - default lock[5] code: - default lock[6] code: - default lock[7] code: - default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 16 sec Remove/Install battery now ! Smart Fast COM5 [VCP3] selected module v3.92 Action: "sp-unlock" unlock method: smart fast Model: LG-GS310 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: MAUI.09AW0944LGE_WISE_SP.W10.32 Version: ROSEMARY_HW 115 byte(s) read connection Ok 217 byte(s) read reading data... reading data #2... building new data... writing data... 205 byte(s) read reading data... 188 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 22 sec Remove/Install battery now ! Both Method Not Work Plz Infinity Team Help To solve This Problem I Follow All instruction,, BR, Shahid Mahmood |
06-06-2011, 09:35 | #3 (permalink) |
Member: 227428 Status: Offline Thanks Meter: 27 | Here is Readed File and Operation Log COM5 [VCP3] selected module v3.92 Device: LG-GS310 Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0008]: 00EC:00B100000055 [SAMSUNG] K9F1G16Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 01800000/06800000 firmware size: 24Mb ffs size: 104Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.09AW0944LGE_WISE_SP.W10.32 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: A94810B5 bootloader version: ROSEMARY_BOOTLOADER_V005_MT6235B_MAUI_09AW0944LGE_ WISE_SP_W10_32 nfi area detection (2 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW0944LGE_W ISE_SP_W10_32.BIN project-id: MAUI.09AW0944LGE_WISE_SP.W10.32, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Shahid\Desktop\LG-GS310_ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW094 4LGE_WISE_SP_W10_32__fullflash_20110606-124152.B4M.bin Disconnect... done Finished, time used: 46 min 19 sec Remove/Install battery now ! LG-GS310_ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW094 4LGE_WISE_SP_W10_32__fullflash_20110606-124152.B4M.zip - 4shared.com - online file sharing and storage - download |
06-14-2011, 21:11 | #4 (permalink) |
Freak Poster Join Date: May 2004 Location: Riga , Latvia Age: 43
Member: 66399 Status: Offline Thanks Meter: 42 | Phone unlock problem solved! but it isnt easy first of all , write flashfile from support which kills the phone ( probably these phones which doesnt unlock as intended are with "new , protected fw ") then with Gsmmulti write original lg fw ( phone is alive but with defailt imei ) and finally - repair imei with Infinity , and all done |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
