02-03-2016, 08:39 | #1 (permalink) |
Registered User Join Date: May 2006 Location: ROMANIA - BISTRITA Age: 44
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | LG x150 flash problem |
02-19-2016, 18:19 | #4 (permalink) |
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | PASSIONATE_BOYS here is log : Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D42005682D25D9235 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42005682D25D9235 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : BD277AE5C7759F681E264356BB853008 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : full_v10 ProdModel : v10 Device : v10 AndroidVer: 5.0.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_ARIMA6582.W.L_P110 SECURITY : IMEI_SW [1] : 35xxxxxxxxxxxxx BTMAC Addr : xxxxxxxxxxxxx WiFi MAC : xxxxxxxxxxxxx MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1449_MD_WG_MP_V1_P12_1_wg_n EXTRA : LCD [0] : jd9161ba_dsi_vdo LCD [1] : hx8379c_fwvga_dsi_vdo LCD Res : 854x480 TOUCH [0] : ektf2131 CAM [0] : s5k5e2ya_mipi_raw CAM [1] : s5k4h5yx_mipi_raw CAM [2] : s5k5e2fr_mipi_raw ov2685_mipi_yuv MODEM : arima6582_w_l_hspa LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:34 Reconnect Power/Cable! Thanks ! |
02-20-2016, 08:20 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Find correct firmware and Init Preloader or flash your phone. Preloader is erased so phone can't get switch on. Br. Infinity Box Support Team. |
02-20-2016, 12:25 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It is X series LG. I had added original LG initial support from v1.41 ( original and bootrom mode ), but not activated yet FW read and writing. It almost all secured phones. |
02-20-2016, 18:49 | #7 (permalink) |
Member: 279656 Status: Offline Sonork: 1684319 Thanks Meter: 7 | I have 2 pieces ! One working and one not ! Here is the second log from working one : Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 48 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200542FD28A9259 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200542FD28A9259 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 5F3926619D5E941115565CD13FD92EEA INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : full_v10 ProdModel : v10 Device : v10 AndroidVer: 5.0.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_ARIMA6582.W.L_P110 SECURITY : IMEI_SW [1] : 351xxxxxxxxxxxxxx BTMAC Addr : C49xxxxxxxxxxxxx WiFi MAC : C49xxxxxxxxxxxx MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1449_MD_WG_MP_V1_P12_1_wg_n EXTRA : LCD [0] : jd9161ba_dsi_vdo LCD [1] : hx8379c_fwvga_dsi_vdo LCD Res : 854x480 TOUCH [0] : ektf2131 CAM [0] : s5k5e2ya_mipi_raw CAM [1] : s5k4h5yx_mipi_raw CAM [2] : s5k5e2fr_mipi_raw ov2685_mipi_yuv MODEM : arima6582_w_l_hspa LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:32 Reconnect Power/Cable! This one also show "PreLoader : NOT Active [ Erased ]" and phone booting and all is ok ! I did copy firmware from working phone to not working phone ,and still the same problem -not booting ! I have original NVRAM and all sequrity area are ok ! with 1.41 i can see this ! |
02-28-2016, 12:20 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Please, not try play with LG original phones. They a very different from standard MTK phones. |
