10-03-2016, 06:38 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | LG X210 [Secure Boot] Factory FW flashing test Code: Operation : Flash [ v1.57 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D42007F1AD3F7C259 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42007F1AD3F7C259 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB37B1BC7B03A61B9FFC656261A9810A3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : d5 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : Unknown (not supported or without battery) Backup enabled! Backup saved : Backup\Flash\150100513732534D42007F1AD3F7C259\ BL : Flash Pre-Erase Total blocks to Erase : 3 Erase : 0x0000000001C80000-0x0000000023340000 Erase : 0x00000000250C0000-0x0000000005740000 Erase : 0x000000002B000000-0x00000000E9C00000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 179A BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0016 Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLS Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : FLEX Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:07:41 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : FLEX Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:13 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Done! Elapsed: 00:08:38 Reconnect Power/Cable! |
The Following 11 Users Say Thank You to JayDi For This Useful Post: |
10-06-2016, 07:58 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | X220 firmware uploading on support. X135 firmware uploading on support. X145 firmware uploading to support. Warning! To flash those FW you MUST update MTK to v1.58. |
10-06-2016, 08:26 | #8 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | Quote:
10-06-2016, 09:54 | #9 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
CM2MTK v1.58 is still not released, it's under test. When it will be ready team will release it, hopefully soon. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
