07-22-2016, 14:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: algeria
Member: 2116178 Status: Offline Thanks Meter: 38 | LG X210ds DEAD. Here's Log: Start at : [22-07-2016 / 12:51:13] Operation : Flash [ v1.52 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420032DCD2D543E3 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420032DCD2D543E3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x37F30FDDCCB9A08BCC702DC967E6EAE9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : d5 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4180 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 3 Erase : 0x0000000001C80000-0x0000000023340000 Erase : 0x00000000250C0000-0x0000000005740000 Erase : 0x000000002B000000-0x00000001A5F80000 Flash Pre-Erase Done, time used : 00:00:13 SecCfg Passed , 179A BMT remark not need. Will skip Sending Preloader ... Use : preloader_d5.bin Preloader Sent , Init passed SecCfg Passed , 179A PartCount : 0016 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : FLEX Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:05 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : FLEX Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:28 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:09:06 Reconnect Power/Cable! Finish at : [22-07-2016 / 13:00:18] Start at : [22-07-2016 / 13:00:50] Operation : Format FileSystem [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420032DCD2D543E3 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420032DCD2D543E3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x37F30FDDCCB9A08BCC702DC967E6EAE9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Format/Reset Error! Operation Failed Elapsed: 00:01:42 Reconnect Power/Cable! |
07-22-2016, 18:02 | #6 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: mystery city
Member: 1199392 Status: Offline Thanks Meter: 95 | Quote:
Sent from my LS-5009 using Tapatalk | |
07-23-2016, 15:01 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: Algeria
Member: 274054 Status: Offline Thanks Meter: 400 | here is flash file reading from working phone by BEST dongle https://mega.nz/#!KodDTK6L!-jhEtNmF1...hbdwreHW6HUclg |
The Following User Says Thank You to FayGsmDz For This Useful Post: |
07-24-2016, 15:09 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Sure it will be dead, because it not supported yet completely. I understand - better read and follow posts of ordinary users and hope on success, instead of author ones. |
08-02-2016, 22:59 | #12 (permalink) |
Freak Poster Join Date: Oct 2014 Location: algeria Age: 35
Member: 2266626 Status: Offline Thanks Meter: 40 | I think a full dump can fix the problem. But its over then 8g i cant update it. Sorry |
The Following User Says Thank You to ibrahimtr For This Useful Post: |
03-28-2018, 12:52 | #14 (permalink) |
Junior Member Join Date: Jul 2015 Location: Azad Kashmir
Member: 2432467 Status: Offline Thanks Meter: 0 | LG X210ds Help Me Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM4) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot11 ... >>ERR21002.00 Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM4) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... ERR21002.00 |
