06-10-2016, 01:17 | #1 (permalink) |
Registered User Join Date: Sep 2005 Location: (earth°) Age: 46
Member: 181110 Status: Offline Sonork: 1001648353 Thanks Meter: 180 | lg x210ds reset FRP DONE thanks infinity team Code: Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200168A6A95332B Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200168A6A95332B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x57A0869FCC64D772FB7718BDCB10C8A2 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to smart_clip For This Useful Post: |
06-10-2016, 05:38 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Yes, they supported for basic stuff - Reset FRP , read or reset userlocks , wipe, read info. Repair security, firmware operations and etc. will follows in next versions. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
07-17-2016, 12:10 | #3 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 926208 Status: Offline Thanks Meter: 71 | LG K7 X210DS FRP LOCK OK SELECT VOLUME DOWN ( - ) AND OK Operation : Format FileSystem [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200C4B79A554307 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200C4B79A554307 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x87EB1BBC1729AA313C26B0FF766A859B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to khassene01 For This Useful Post: |
08-01-2016, 14:23 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | |
The Following 2 Users Say Thank You to ..::Mr999::.. For This Useful Post: |
08-13-2016, 16:25 | #6 (permalink) |
Junior Member Join Date: Feb 2014 Location: Lagos, NG
Member: 2133401 Status: Offline Thanks Meter: 1 | Hello everyone. I was googling about this frp thing and it lead me here where I clicked on that link of the firmware which I downloaded and used sp flashtool to flash my LG-X210ds (seems to be a Russian variant) and now the phone is neither displaying nor booting up. To be more specific I first checked the phone's info, and it's showing that the chip is MT6580 it was on android 5.1. Now when I try to flash again it gives me this error S_SECURITY_SECURE_USB_DL_IMAGE_SIGN_HEADER_NOT_FOU ND (6045) MSP ERROR CODE : 0x00 HINT: I downloaded the latest sp flashtool which is v5.1628 but still I got the same error. I googled the problem I got info telling me first that it may be due to the unlocked bootloader or a driver conflict. The last made me check in the Computer manager and I saw that when it connects to the computer LGE drivers show up and MTK USB PORT one after another. Is there something wrong with the firmware or I did. If anyone can help I'll be grateful. |
08-13-2016, 16:54 | #7 (permalink) | ||||
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Quote:
2nd thing firmware been tested then uploaded , read with tool which we all professional use , and readed with both methods - Factory and CM TOOL Supported , another thing i have posted very well described info which is relates with the phone WE NEVER WROTE HERE USE THIS FILE FOR REMOVE FRP BY FLASHING THIS FIRMWARE , FIRMWARE UPLOADED BECAUSE Another user need and phone had issue ( for sure not FRP ) , UPDATE Firmware only for 2 Purpose 1 : Only if you need to update direct OS of your Phone 2: Phone have the issue related software and firmware flashing fix it . 3: NO ONE UPDATE Firmwares without check versions compatibility & if do then results upon your actions if any any case firmware not relates to the device . VERY WELL I POST ALL INFO WHICH IS From phone which we use to read firmware . Firmware : MT6580__lge__LG-X210__m13g__5.1__ALPS.L1.MP6.V2.19_ARIMA6580.WE.L_ P42 Quote:
if you need i can help you to do something for flash the phone if there is nothing more went wrong than expected , you should read the firmware info then must compare all the info before flash the phone , because only CPU is not the thing we need to flash the correct firmware , we need to check if phone model is same because each variant for same models never same , its depend on the country they make the phone and use the firmware for their side needs , many time same model different variant have hardware changes as well as you said your device is : LG-X210ds and our file is from : ProdModel LG-X210 and you dont have proper info readed even , you could do with some free tools before do anything and if you found this thread and you could ask before doing flash . i just ask if you have infinity CMTOOL or no ? ( i think no because if you had you never need use sptool direct for frp ) . P.S = i did explain as much as i can , waiting your answer now . | ||||
The Following User Says Thank You to ..::Mr999::.. For This Useful Post: |
08-13-2016, 17:41 | #8 (permalink) |
Member: 2133401 Status: Offline Thanks Meter: 1 | As far as I'm concerned everything you said is right. the reason why I used sp is because the firmware downloaded could be read by the flash tool. And I admit I ignored some slight details about the phone's details and I can't blame the uploader. Yes I don't own Infinity but I have Miracle Box which I bought two years ago but it doesn't support this phone. I should have asked before flashing. Is there any way I can find this file? And would you guide me how to flash it? Plus the reason why I flashed to remove frp is cause I have been able to do so on a Tecno device which has the same chip (MT6580). Though phones are different but I believed tools can be used on both I was wrong. Thanks for your assistance until now anyway. |
The Following User Says Thank You to apostlekays For This Useful Post: |
09-17-2016, 18:19 | #9 (permalink) |
Member: 926208 Status: Offline Thanks Meter: 71 | LG K7 X210DS FRP LOCK OK SELECT VOLUME DOWN ( - ) AND OK Operation : Format FileSystem [ v1.53 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200C4B69B36435B Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200C4B69B36435B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xCE1706B938BA8757A7977854C2AFD914 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:02:04 Reconnect Power/Cable! |
The Following User Says Thank You to khassene01 For This Useful Post: |
01-10-2017, 11:10 | #10 (permalink) |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | Lg.x210 frp done by miracle box.cone click and unlock |
The Following 3 Users Say Thank You to khalidahmed For This Useful Post: |
03-06-2017, 13:42 | #11 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Romania
Member: 730652 Status: Offline Thanks Meter: 74 | lg x210 FRP remove MTK module v1.58 down key press Format FS/ Reset seting Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200EE5A9A202327 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200EE5A9A202327 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xDBC63AE9E22EA8D65C00315224FDB1F5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:48 Reconnect Power/Cable! thank infinity team |
The Following User Says Thank You to jordachi For This Useful Post: |
05-09-2017, 14:03 | #12 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Algiers, Algeria Age: 52
Member: 339377 Status: Offline Thanks Meter: 18 | lg k7 x210ds frp remove donne by Infinity Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D4200BAAA97A4A33B Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200BAAA97A4A33B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x66A416D6D59F2BC0B5ED9A4CD320D103 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to hapios For This Useful Post: |
08-19-2017, 13:50 | #15 (permalink) |
Insane Poster Join Date: Aug 2015
Member: 2443309 Status: Offline Thanks Meter: 14 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420065B29623331D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420065B29623331D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xBE00A96A758B99FD18A14E58434CD677 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
