11-25-2008, 19:39 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | lg195 problem shotout by infinity problem shotout by infinity simply 1st formate whole chip n than flash COM4 [VCP0] selected module v2.41 Device: LG-KG195 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:7B41:11FC boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: F:\infinity box\InfinityBox\MModule\eeprom_20081125-235509.B0Ekg195 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 98004900000002:FFFFFF00000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 85837 sec Remove/Install battery now ! ur problem will gone thanks infinity for made this |
The Following User Says Thank You to robin25 For This Useful Post: |
12-19-2008, 18:19 | #2 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 364696 Status: Offline Thanks Meter: 16 | same problem here this thread did not work for me.teami have read all threads about kg195 shows lg log and trun off.i have done every thing like "safe ffs, complte ffs, whole flash ffs, write firmware (files given in Suport Area, repair eeprom, problem same.what is its FINAL solution PlZ. |
12-19-2008, 19:51 | #3 (permalink) | |
Vodafone 125 Restart Problem Solved By Infinity | zeel_zeel | Infinity-Box | 4 | 07-23-2010 08:25 |
how to convert other file not seen by infinity to be seen by infinity? | GOODNESS | Infinity-Box | 1 | 05-22-2009 21:48 |
chinese phone calibrate touchscreen problem solve by infinity | robin25 | Infinity-Box | 2 | 03-07-2009 09:34 |
problem with flash by infinity on this phone | sirnavid2010 | Infinity-Box | 16 | 01-28-2009 13:56 |
help c139 spunlock problem by infinity | nitinkansara | Motorola ODM | 6 | 01-28-2009 05:53 |
