Old 12-10-2009, 10:14   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Heare is sigmatel t2 new firmware detected
HEARE IS SIGMATEL T2 NEW FIRMWARE DETECTED
HEARE IS FULL OK SET READED LOG:-
COM6 [VCP0] selected
module  v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9003:000E
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.02, database date: 10.12.2009):
A519_T2_PCB01_GPRS_MT6225_S00.A519_T2_LAN_V3_2.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info protocol ver: 04
ver. sw 1: A519_T2_PCB01_GPRS_MT6225_S00.A519_T2_LAN_V3_2.BIN
ver. sw 2: A519_T2_LAN_V3.2, 00000000
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: A519_T2_PCB01_GPRS_MT6225_S00.A519_T2_LAN_V3_2__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\A519_T2_PCB01_GPRS_MT6225_S00.A519_T2_LAN_V3_2__fullflash_20091210-143433.B0M SIGMATEL T2
Finished, time used: 480 sec
Remove/Install battery now !
HEARE IS UPLOADED FILE LINK:-
The Following 2 Users Say Thank You to debmobile For This Useful Post:
Old 12-10-2009, 20:32   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you for sharing this flash file!
Old 12-18-2009, 16:59   #3 (permalink)
Member: 254023
good share.....................
Old 12-19-2009, 08:59   #4 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
nice share..............
Old 08-12-2010, 20:03   #5 (permalink)
Member: 1277146
Thanks Meter: 4
sir give this flash file on support area.........plz
Old 08-12-2010, 20:04   #6 (permalink)
Member: 1277146
Thanks Meter: 4
sir i have sigmatel EXD T2 when mp3 play from file manager it has no problem but when i want to play from audio player it showing MSDC Write sector error Some time showing Empty.After this when i go back to file mgr IT showing Empty.
i have already complete format by infinity but same problem.Now i want to flash full firmware .but this firm are not in support area.
firmware name is
KCM25_GEMINI_PCB01_GPRS_MT6225_S00.FS_F618_DS_T2_2 8_V1__fullflash_20100620-142857.B0M
please give me this firmware.
Old 08-12-2010, 20:11   #7 (permalink)
Member: 148515
hello!
make full backup and try this pair:
flashfiles/ChineseMiracle/_MT6225/eeprom/SW_2882L1_EN_PCB01_GPRS_MT6225_S00.SW_2882L1_EN_V0 12_M11_TIANYU.B0E.bin
flashfiles/ChineseMiracle/_MT6225/SW_2882L1_EN_PCB01_GPRS_MT6225_S00.SW_2882L1_EN_V0 06_M11_TIANYU_16m_En_Ru_Nl_Fr_Es_It_De_Ml_Id_Th_Vn _Tr_Farsi_Pt_Ar.B0M.bin
Old 10-18-2010, 01:39   #8 (permalink)
Member: 1277146
Thanks Meter: 4
i tried to flash with that pair of file but set became dead.No upgrade result sir.give me please another solution.
Old 10-18-2010, 19:00   #9 (permalink)
Member: 148515
hello!
unfortunately, we dont have any other files to advice.
best way is to restore backup and return phone to customer
Old 12-31-2010, 20:07   #10 (permalink)
Member: 1277146
Thanks Meter: 4
This handset is mine. I had purchased for sell, but unfortunate it has this type of problem.
Sir kindly tell me ..... Is it hardware or software problem???????????
Old 01-02-2011, 20:49   #11 (permalink)
Member: 148515
hello!
it might be software and hardware problem as well as unsupported MP3 coding.
hard to say anything for sure without making tests
Old 03-14-2011, 23:57   #12 (permalink)
Member: 1277146
Thanks Meter: 4
i saw in other same set of another person,,that is working well......
Old 03-15-2011, 19:55   #13 (permalink)
Member: 148515
hello!
exactly same file?
Old 05-16-2011, 19:18   #14 (permalink)
Member: 1277146
Thanks Meter: 4
hello!
exactly same file?
not confirm........but model +menu+purchase was same time
Heare is sigmatel 7600 new firmware detected debmobile Infinity-Box 12 05-21-2010 08:41
Sigmatel 5130 new firmware detected debmobile Infinity-Box 2 01-21-2010 20:44
Heare is simoco sm-324 new firmware detected debmobile Infinity-Box 5 12-20-2009 16:47
Here is sigmatel s3 new firmware bhavesh123 Infinity-Box 2 12-10-2008 18:36
6300 New firmware detected...what is this? KUBAT1 Infinity-Box 7 01-12-2008 22:58
Page generated in 0.22621 seconds with 10 queries
