06-25-2008, 17:16 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Sweden
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | lgkg290 dead by infinity COM10 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35030526000000 1_LG KG290_20080626-090809.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 010A0000:00020000 Write Fail Finished, time used: 419 sec Remove/Install battery now ! now set condition is dead i need help |
06-26-2008, 10:00 | #3 (permalink) | |
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | Quote:
here logs COM10 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 357456012407089 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601240708 9_LG KG290_20080627-020111.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 89881600010001:89881600000000 Write Done error: wrong answer: C1 Finished, time used: 31 sec Remove/Install battery now ! | |
06-26-2008, 11:15 | #5 (permalink) | |
COM10 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35030526000000 1_LG KG290_20080627-030406.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 010A0000:00020000 error: no any expected answer error: flash write error: 010A0000:00020000 Write Fail Finished, time used: 148 sec Remove/Install battery now ! | |
06-26-2008, 14:32 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2007 Location: Inside of my computer
Member: 490708 Status: Offline Sonork: 100.1587135 Thanks Meter: 569 | Ma Answer is simple.Read flash from another live kg290.Then flash it ur fone with that backup u read b4 from live kg290.hope it,ll work.Check & post ur good result. Br |
06-26-2008, 18:01 | #10 (permalink) | |
here flashed unchecked smart write same error COM10 [VCP4] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35030526000000 1_LG KG290_20080627-095309.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 01020000:00020000 Write Fail Finished, time used: 66 sec Remove/Install battery now ! | |
08-12-2008, 16:27 | #12 (permalink) |
Freak Poster Join Date: Nov 2006 Location: front of computer Age: 44
Member: 398035 Status: Offline Thanks Meter: 51 | yes its worked. i have same problem but now its solved with download previous version of lga.and now my lg kg290 worked fine.its was dead by latest lga 1.31 version. |
help infinity team, v670 dead by infinity !! | wejwej | Infinity-Box | 3 | 07-08-2009 09:38 |
C2200 Dead By Infinity Box | alamgarh | Infinity-Box | 4 | 02-22-2008 10:02 |
Lobster 575 Dead By Infinity | alamgarh | Infinity-Box | 1 | 02-22-2008 09:29 |
KG200 Dead by Infinity how 2 revive it ? | GSMBALOCH | Infinity-Box | 26 | 11-26-2007 19:42 |
j100i dead by infinity | .::ricky rayya::. | Infinity-Box | 5 | 04-30-2007 17:28 |
