07-02-2011, 13:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: BISMI TRONICS
Member: 598334 Status: Offline Thanks Meter: 111 | ===> lgs310 unlocked(sp) successfully STEP 2 : Flash The Phone with GSMMULTI Using Original Flash files (Flash File & Dll file available in Hwk support site) After Power on Ur mobile will be unlocked successfully with defect IMEI. STEP 3: Change Ur mobile original IMEI in MODE1 Using Infinity. ALL DONE. Regards, BismiTronics, Chennai. |
The Following User Says Thank You to coolshahul For This Useful Post: |
07-04-2011, 22:01 | #3 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 596071 Status: Offline Thanks Meter: 160 | Quote:
07-05-2011, 18:47 | #4 (permalink) |
Member: 596071 Status: Offline Thanks Meter: 160 | My set is dead now dont follow this method i detect pin out with gpg dragon and format whole chip but set noe dead and cant dect and usb malfunction any solution for reviving my set |
07-06-2011, 17:39 | #7 (permalink) |
Member: 598334 Status: Offline Thanks Meter: 111 | flash your phone with GSM MULTI using original flash file and dll file (available in Hwk support site) , if you dont know how to flash with GSM MULTI, use search in forums. |
07-06-2011, 17:43 | #8 (permalink) |
Member: 598334 Status: Offline Thanks Meter: 111 | if you do whole flash chip format, every mobile will dead, its well known by every technician, connect the phone using RX TX in infinity, then select infinity port in GSM MULTI, start flashing. |
07-07-2011, 10:40 | #10 (permalink) |
No Life Poster Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | Please these are the files for this phone LG S310, hope it helps all who need them, gsmulti_v30.zip LGS310_steps.pdf LGS310_100913.zip LGS310AT-00-V10d-CIS-XXX-NOV-24-2010.zip |
SL45 blue L.e.d install SUCCESS!!!!!! opened phone :):) | bluelights | x1x to x45/x50 | 4 | 10-01-2001 21:04 |
Can someone success on A3x repair phone? | nok | x1x to x45/x50 | 0 | 08-14-2001 23:44 |
STILL NO Success in disabling the PHONE CODE in C28 v61 | ed2k_7 | x1x to x45/x50 | 1 | 07-31-2001 17:34 |
SUCCESS in Repairing 3310 Contact Service (Double-blink) using NFREE by ViperBJK | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 07-08-2001 16:00 |
s35 successfully killed.... | landy | x1x to x45/x50 | 0 | 06-24-2001 12:50 |
