01-18-2009, 02:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: MUMBAI Age: 53
Member: 41672 Status: Offline Thanks Meter: 195 | Loading failed, probably damaged data file readed log COM10 [VCP1] selected module v2.74 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:BF03:0008 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:08000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:08000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:08000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:08000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 080000000800000018F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V034.BIN ver. sw 2: S4_TOSHIBA_EFIAPVRHMIT_V034, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:08000000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs/eeprom size detection error: can't detect ffs/eeprom address/size error: chip layout not detected error: chip layout not detected Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 27 sec Remove/Install battery now ! Loading file v.01... Loading failed, probably damaged data file i select flash file BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V035__Sigmatel-S3_16m_En_Ru_Fr_Hu_It_Ml_Id_Vn_Tr_Farsi_Ar.bin getting me error Loading failed, probably damaged data file phone flash file BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V034.BIN pls. upload this flash file why getting me this error Loading failed, probably damaged data file thanks |
01-18-2009, 21:39 | #4 (permalink) |
Member: 41672 Status: Offline Thanks Meter: 195 | yes i download first 16mb file anyway i download 8 mb flash file & flash phone work fine but how to flash with 16 mb flash file pls. tell me Last edited by TechPhone; 01-18-2009 at 21:46. |
Alway's Show - error: data error ! Loading failed, probably damaged data file | amol_sm | Infinity-Box | 4 | 09-12-2009 00:20 |
Damaged data file in support! | JoAoOpAuLo | Infinity-Box | 3 | 05-09-2009 18:47 |
6300 RM217 Probably Damage Data File | zahidnawaz | Infinity-Box | 2 | 12-30-2008 07:34 |
N95 1-SIM 2-SLIDER N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32 Damaged data file | fastlink Jogja | Infinity-Box | 4 | 12-10-2008 18:29 |
LOAD FAILED PROBABLY DAMAGED DATA FILE...why showme this???? | mangofree | Infinity-Box | 6 | 09-29-2008 21:34 |
