Old 04-27-2009, 10:46   #1 (permalink)
Member: 269885
Thanks Meter: 50
lobster 544 flash problem
i have a lobster 544 in dead condition wen i flash it successfully and try to power it on it powerd on but after 1 minut it became off den i flashed its eeprom file successfuly but still same problem.wen i try to unlock itit gives faild and showd eeprom damage.wats the problem and wats its solution.the log is as follow
COM4 selected
module v2.68
Device: Lobster-544
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6219:8A01]...
CPU: MT6219
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: B0001D00000000:B0001D00000000
flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detection phase #2...
detect device identification#1 finished
identification#1 protocol ver: 01
ver. sw 1: MP500_UK_PCB01_GPRS_MT6219_EV.MP500_W05_20_MP_V53. BIN
ver. sw 2: MP500.W05.20.MP.V53, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[MP500_UK_PCB01_GPRS_MT6219_EV.MP500_W05_20_MP_V53. BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[MP500_UK_PCB01_GPRS_MT6219_EV.MP500_W05_20_MP_V53. BIN]_20090427-125130.9AE.bin
Backup required data Done
Patch required data ...
detection procedure, wait...
error: phone is not locked or unknown eeprom
Patch required data Fail
Finished, time used: 157 sec
Remove/Install battery now !
Old 04-27-2009, 14:07   #2 (permalink)
Member: 269885
Thanks Meter: 50
wen i try to read codes i got the following log
COM4 selected
module v2.68
Action: read codes
unlock method: read codes
Model: Lobster-544
19200 autodetect
CPU: MT6219
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6219,E01
Date: 2004.06.18
Version: 1.2.1.4
Version: MP500.W05.20.MP.V53
Version: VerH/W:0.1
65 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
69 byte(s) read
Phone lock: Off
Network lock: On
Network subset lock: Off
Service provider lock: On
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
NP code: 89829610/98286901
locked to: 234-30
SP code: 0000000000003344/0000000000003344
CP code: FFFFFFFFFFFF0000/FFFFFFFFFFFF0000
Phone code: 0000000000000000
Finished, time used: 29 sec
why it shown red colour marked code like that wat its mean,wats the problem wid fone
Old 04-27-2009, 14:27   #3 (permalink)
abid dar's Avatar
Member: 621787
Thanks Meter: 142
You use latest madul ok your prb have solve..................ok dear
The Following User Says Thank You to abid dar For This Useful Post:
Old 04-27-2009, 14:43   #4 (permalink)
abid dar's Avatar
Member: 621787
Thanks Meter: 142
You use latest madul............ok
Show link here.........
http://rapidshare.com/files/22633598...v2.71.rar.html
Plz reply i wait your result...ok
The Following 2 Users Say Thank You to abid dar For This Useful Post:
Old 04-27-2009, 15:17   #5 (permalink)
Member: 269885
Thanks Meter: 50
thx br for reply i wll chk n post result
Old 04-27-2009, 16:51   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It is need to use latest MModule v2.71.
Old 04-28-2009, 06:10   #7 (permalink)
Member: 269885
Thanks Meter: 50
thx abid br my problem solved wid that latest module
Old 04-28-2009, 08:03   #8 (permalink)
abid dar's Avatar
Member: 621787
Thanks Meter: 142
ok brother thanks for your reply for successfully report.............
Lobster 544 problem unlock jonnn FuriousGold 7 02-03-2007 17:15
AGAIN: FIRST IN THE WORLD - Lobster 544 SUPPORTED Gobi VygisToolbox 18 09-21-2006 08:42
lobster 544 ERROR plz SOlve UHK VygisToolbox 4 08-16-2006 22:26
lobster 544 547 GONDOLF VygisToolbox 1 08-16-2006 13:35
lobster 544 cable tical VygisToolbox 1 08-04-2006 23:47
Page generated in 0.23270 seconds with 9 queries
