09-11-2008, 09:31 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | Lobster 575 flashing succesfully done COM26 [VCP0] selected Device: Lobster-575 "advanced chip detection" active Action: flash write "smart write" active "safe mode" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot done Check connection... Check connection done Set baud... 406250 Set baud done Check hardware... flash: 01227E22212200:8AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Check hardware done Read data... reading Lobster-575_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Lobster-575_eeprom_calibration-1_20080911-125058.92E.bin reading Lobster-575_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Lobster-575_eeprom_calibration-2_20080911-125641.92E.bin Read data done Check data... Check data done Writing... Area: Firmware "safe mode" active flash: 01227E22212200:8AEA0000000000 Write: Firmware "safe mode" is not active flash: 01227E22212200:0C434200000000 Write: Firmware Writing done Finished, time used: 399 sec Remove/Install battery now ! thanx to infinity |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
09-11-2008, 09:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Lobster 575 not supported for flash and repair ?! | jawad8305 | FuriousGold | 4 | 11-11-2008 18:24 |
Lobster 485 And Lobster 575 Full Support Added ! | irfanamin2 | FuriousGold | 2 | 07-26-2008 10:24 |
25/07/08 Lobster 485 And Lobster 575 Full Support Added ! | DARIFBS | FuriousGold | 1 | 07-25-2008 16:36 |
FIRST IN THE WORLD: Lobster 575 SUPPORTED !!! | Gobi | VygisToolbox | 10 | 07-13-2006 17:07 |
