08-17-2010, 16:56 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Lobster 575 unlock problem module v1.38 Device: Lobster-575 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail error: operation failed Finished, time used: 21 sec Remove/Install battery now ! |
08-18-2010, 09:01 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, check Infinity-Box Shell, you will see two types of pinouts for this phone. Please, use 2nd pinout (not the same as you have tried already). |
08-18-2010, 09:23 | #3 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | HI I have tried both of these keyboard top 1.........24 13: Box Rx/Phone Tx (RJ45 pin-3) 14: Box Tx/Phone Rx (RJ45 pin-2) 24: Gnd 17: Box Rx/Phone Tx (RJ45 pin-3) 18: Box Tx/Phone Rx (RJ45 pin-2) 24: Gnd but no response COM5 [VCP0] selected module v1.38 Device: Lobster-575 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! boot version: connecting... error: can't run bootcode Boot fail error: operation failed Finished, time used: 22 sec Remove/Install battery now ! same as before It is only connecting with 7/8 rx/tx and gnd from battery but same position I tried a lot with pinfinder also |
08-18-2010, 09:32 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, please, double check cable again. This phone has two UART (two pairs of Rx/Tx) so if you can not connect via one rx/tx pair (see boot version and then connection lost) you have to use another rx/tx. |
08-18-2010, 10:00 | #5 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Lobster 575 unlock done Sir thank you very much! Actually pinouts were 1.........24 13: Box Rx/Phone Tx (RJ45 pin-3) 14: Box Tx/Phone Rx (RJ45 pin-2) 24: Gnd give in shell but not connecting with this I tried reverse of these pinouts which mean 1.........24 and if we count reverse from 24-23-22--------1 then it is 13/14 tx rx If we count like 1.............24 from TOP left to right then it is 11/12 rx and on this pinouts 11rx 12tx phone connected-- thanks to Infinity support Here is the log : Code: COM5 [VCP0] selected module v1.38 Device: Lobster-575 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 01227E22212200:8AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Check hardware done Read data ... reading Lobster-575_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Lobster-575_eeprom_calibration-1_20100818-013310.92E.bin reading Lobster-575_eeprom_calibration-2... warning: wrong data size at 0x0182E000, retry... read error recovered file saved: C:\Program Files\InfinityBox\HModule\Lobster-575_eeprom_calibration-2_20100818-014554.92E.bin Read data done Check data ... file saved: C:\Program Files\InfinityBox\HModule\eeprom_20100818-015851.92E.bin wait... pass-1... pass-2... pass-3... Check data done Write ... flash: 01227E22022201:FFFFFF00000000 Write: eeprom Write done Finished, time used: 26 min 49 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to azeem781986 For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
