12-02-2006, 15:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | ((( Lock Code X700 Removed luv Infinity ))) Select eeprom from support (only one available) Select Reset to Defaults Flash EEPROM as Firmware Main (when selecting file underTAB select Allfiles) After Done Power On ur phone and Give a Kiss to This Infinity BOX Thankx Again.....Long Live Infinity Team ...... |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
12-02-2006, 22:57 | #2 (permalink) | |
Insane Poster Join Date: Jul 2005 Age: 55
Member: 166086 Status: Offline Thanks Meter: 9 | Quote:
12-12-2006, 11:44 | #6 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | some clarifications. original X700 USB cable must by used (or should the x70 cable be used) Should the phone be turn on and installed drivers (or should the x70 and infinity box be used) then select port for X700 modem ? Then Flash Eeprom file or must the phone be in some form of test mode when installing the EEprom file ? |
08-29-2007, 10:47 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | if you want to make unlock you must read documentation. D:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_X700_X701 If you want to clear user code you must read first message in this thread. Don't be lazy, read before ask ! |
08-29-2007, 15:08 | #13 (permalink) | |
No Life Poster Join Date: Jan 2003
Member: 20069 Status: Offline Thanks Meter: 131 | Quote:
kiss to infinity box. BR | |
02-20-2009, 17:23 | #14 (permalink) | |
Major Poster Join Date: Apr 2004 Location: Russia, Samara Age: 56
Member: 61039 Status: Offline Thanks Meter: 67 | Quote:
This method exactly worker at presence Pana01_1.62 è eeprom: X700_eeprom_static_03.30E.bin, X700_eeprom_static_04.30E.bin, X700_eeprom_static_05.30E.bin ? Flash EEPROM as EEPROM that does not work ... Flash EEPROM as Firmware ? | |
T919 need help for personal lock code to remove | mymiela0419 | UST Pro II | 10 | 07-02-2009 06:03 |
i550w lock code not remove | farshad2009 | Samsung Flashers, Software, Firmware. | 0 | 10-21-2008 14:26 |
x700 user lock can be removed? | Raklm | Infinity-Box | 3 | 03-14-2007 14:11 |
Pana x700 phone lock code | Alex8392003 | Panasonic | 10 | 12-14-2005 16:32 |
HELP!!! Forgot lock code X700... | ProKakashi | Panasonic | 8 | 08-18-2005 06:39 |
