Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314
Thanks Meter: 147 | logic x1 slot is permanently blocked unable to unlock logic x1
pls help with Quote:
Card found : S/N : D87EAC71 , v0134
Operation : SP Unlock [ v1.58 ]
Mode : Read Codes
Wait for phone...
Phone found! [ 59 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 700100533130303034086144D3795239
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 40001
[eMMC] : FLASH_CID : 700100533130303034086144D3795239
[eMMC] : FLASH_LEN : 0x00000000E4000000
[eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB]
DEV RID : 0xA02898634A36802BDFECE69ADC7115B3
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Slot[1] SIMLock Info :
[1] Level , [Locked] : False
[2] Level , [Locked] : False
[3] Level , [Locked] : False
[4] Level , [Locked] : False
[5] Level , [Locked] : False
[6] Level , [Locked] : False
[7] Level , [Locked] : False
Slot[2] SIMLock Info :
Done!
Elapsed: 00:00:38
Reconnect Power/Cable!
Mode : Direct Unlock
Wait for phone...
Phone found! [ 59 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Lock Status : Not Locked!
Done!
Elapsed: 00:00:16
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 59 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : LOGIC
ProdName : Vandroid
ProdModel : LOGIC X1
Device : Vandroid
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
SECURITY :
IMEI_SW [1] : 910604100024866
BTMAC Addr : 7AEE46657242
WiFi MAC : 000822019202
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_wg_n
EXTRA :
LCD [0] : hx8357d_hsd35_hlt_hvga
LCD [1] : ili9488_ivo35_wuyang_hvga
LCD Res : 480x320
TOUCH [0] : GT9XX
TOUCH [1] : ft5306
CAM [0] : gc2035_yuv
CAM [1] : gc0328_yuv
CAM [2] : gc0311_yuv
MODEM : vanzo72_wet_jb3_wcdma
LOCALE : en_US ar_IL be_BY da_DK de_DE el_GR en_GB es_ES fa_IR fi_FI fr_BE fr_CA in_ID lt_LT my_MM pl_PL rm_CH sk_SK sl_SI th_TH zh_CN zh_TW zu_ZA
Done!
Elapsed: 00:00:20
Wait for phone...
Phone found! [ 59 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:16
Mode : Read Codes
Wait for phone...
Phone found! [ 59 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:14
Reconnect Power/Cable! | |
