Same problem Code:
Card found : S/N : 334FA6A3 , v0136
Chinese Miracle II [MTK module] v 1.57
Operation : Flash Erase [ v1.57 ]
Wait for phone...
Phone found! [ 62 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 7001004D4D43303447585BF11617B1C1
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , G40CM
[eMMC] : FLASH_CID : 7001004D4D43303447585BF11617B1C1
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E6800000
[eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB]
DEV RID : 0x4B1992B13EB4BCC71D255BFBAB37A268
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Keep Preloader alive
Flash erase done
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Scatter Load Ok , BaseBand : MT6572 , Project : ipro72_w_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Logicom
Device Model : L-EMENT350
Device CPU : MT6572
Device IntName : L-EMENT350
Device Version : 4.4.2
Device Compile : 20/05/2015 07:51:31
Device Project : ALPS.KK1.MP7.V1
Device ExtInfo : L-EMENT350
Ready to Flash!
Operation : Flash [ v1.57 ]
======= Flash
Wait for phone...
Phone found! [ 62 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DRAM configured from ScatFW!
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : ipro72_w_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3763 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x00000000E2500000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_ipro72_w_kk.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Write Error , code 0x001! Something went wrong!
Operation Failed
Elapsed: 00:03:45
Operation : HW Test [ v1.57 ]
Wait for phone...
Phone found! [ 62 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [KINGSTON] , G40CM , 0xE6800000 , 3688 MiB
[eMMC] : CID : 7001004D4D43303447585BF11617B1C1
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:41
Wait for phone...
Phone found! [ 62 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3761 mV
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:22
Reconnect Power/Cable! |
