03-10-2019, 14:47 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Nigeria,Delta
Member: 786852 Status: Offline Thanks Meter: 31 | Lumia 550 Unlock Not Successful username pigli000b. Thanks Here is the Log: Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Connecting to server and check info ... Login Ok! Credits : 56 Done Phone not in service mode! Set phone to Test mode first! Phone require ENO for enter in TEST mode!!! You can download ENO file in ENO DL tab! SSChannel : Create SC SSChannel : SC Created! Selected ENO package download for RM-1127 SSChannel : DC Ok with code 0x02 Done! Generated Links : ------------------------------------------------------- https://sr.azureedge.net/softwarerep...WsT1hzPJo90%3D https://sr.azureedge.net/softwarerep...bdGxyKgQPuA%3D ------------------------------------------------------- Done! Phone require ENO for enter in TEST mode!!! You can download ENO file in ENO DL tab! Phone require ENO for enter in TEST mode!!! You can download ENO file in ENO DL tab! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Connecting to server and check info ... Login Ok! Credits : 56 Done Phone require ENO for enter in TEST mode!!! You can download ENO file in ENO DL tab! [WP8x] : Init TesMode [TSTM] : Use File : RM1127_1078.0037.10586.13169.207.62_enosw-wim-signed_638819.secwim === Base Phone Info Sw Version : 01078.00042.16352.50010 IMEI : 355132078909175 ProductCode : 059X5Q9 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone Model ID : Microsoft.MSM8909.P6236.2.0 === eMMC info : eMMC Vendor : Hynix eMMC CID : 0090 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 56BDC3746226E080146D4D30C8C8432657A5282F === Other info : SD present : False SECWIM : RM1127_1078.0037.10586.13169.207.62_enosw-wim-signed_638819.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Connecting to server and check info ... Login Ok! Credits : 0 Done WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Connecting to server and check info ... Login Ok! Credits : 0 Done Phone disconected! Connect phone on selected interface... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Connecting to server and check info ... Login Ok! Credits : 0 Done Phone not in service mode! Set phone to Test mode first! === Main info === NCSD Version : 8.7 Sw Version : 01078.00042.16352.50010 IMEI : 355132078909175 ProductCode : 059X5Q9 ProductCodeB : 059X232 ProductSN : EABF77EAU Module Code : 0206806 === HW info === Public ID : 537968AF49255C19973A527F91157D84CDE249EE HW Version : 3001 BT Addr. : 6C8FB5373071 Wlan Mac : 6C8FB54782BC Battery Level : 52 % === Branding and security info === Operator : 000-88 SimLock : Locked! SimLock : 2341500000000 Country : United Kingdom Operator : vodafone UK Branding : RM-1127_15338 Sec. Mode : Restricted Done! [WP8x] : Init TesMode [TSTM] : Use File : RM1127_1078.0037.10586.13169.207.62_enosw-wim-signed_638819.secwim === Base Phone Info Sw Version : 01078.00042.16352.50010 IMEI : 355132078909175 ProductCode : 059X5Q9 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone Model ID : Microsoft.MSM8909.P6236.2.0 === eMMC info : eMMC Vendor : Hynix eMMC CID : 0090 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 56BDC3746226E080146D4D30C8C8432657A5282F === Other info : SD present : False SECWIM : RM1127_1078.0037.10586.13169.207.62_enosw-wim-signed_638819.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Check SimLock info Conf key : 8000000000000000 Provider key : 2341500000000000 Country : United Kingdom Operator : vodafone UK Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Last edited by mbond; 03-10-2019 at 14:54. |
03-11-2019, 12:57 | #3 (permalink) |
Member: 786852 Status: Offline Thanks Meter: 31 | Successfully unlocked now WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to mbond For This Useful Post: |
