Old 10-17-2016, 11:03   #1 (permalink)
Member: 2298369
Thanks Meter: 440
Lyf ls-4006 frp lock remove
LYF LS-4006 FRP LOCK REMOVE -
Phone found! [ 18 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC9830 eMMC Generic Loader v2 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:22
Reconnect Power/Cable!
The Following User Says Thank You to galaxycompue For This Useful Post:
Old 10-17-2016, 11:38   #2 (permalink)
Member: 2298369
Thanks Meter: 440
i give the handset to customer but when he check lock not removed, he come again i did this process again but frp lock not removed yet.
Old 11-05-2016, 04:47   #3 (permalink)
Member: 942156
Thanks Meter: 2
it can easily done by frp bypass apk app .... i test this app.... 100% ok frp solution...
Old 11-05-2016, 04:52   #4 (permalink)
Member: 942156
Thanks Meter: 2
try bypass frp apk ... your problem will solved....
Old 11-05-2016, 04:56   #5 (permalink)
Member: 942156
Thanks Meter: 2
use this apk ..................................................
Old 11-13-2016, 08:16   #6 (permalink)
Member: 1639881
where is apk file plss give me
Old 11-15-2016, 09:40   #7 (permalink)
Member: 1507500
where is apk file.........................wating
Old 11-22-2016, 09:10   #8 (permalink)
Member: 1102247
Sonork: ashok Nagari
Lyf ls-4006 frp unlock bypass apk
Lyf ls-4006 frp unlock waiting for bypass apk
Old 11-22-2016, 09:41   #9 (permalink)
Member: 2118052
Thanks Meter: 568
Frp solved
Rishabh......980286**28
Old 11-22-2016, 11:02   #10 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Use latest CM2SPD software to remove frp, if any problem post here with logs.
Br.
Infinity Box Support Team.
Old 11-24-2016, 10:01   #11 (permalink)
Member: 2294633
Thanks Meter: 15
LYF LS-4006 FRP LOCK REMOVE with this tool tested from me
1. Mobile Go to fastboot mode
2. Connect mobile with pc
3. Press 9 & enter ok
Android Fastboot Reset Tool V1.2 - Download - 4shared
The Following 8 Users Say Thank You to saifulinbox For This Useful Post:
Old 11-30-2016, 12:06   #12 (permalink)
Fusion Rock's Avatar
Member: 1930738
Sonork: 100.1638397
Thanks Meter: 80
Lyf ls-4006
Put Nova Launcher And QuickShortcut Maker On ur SD Card
First On Ur Phone ...Put ur phone Asking Google Account.. Then Hold @key Scroll than settings.... Then select Keypad Settings. ...and Select Typing settings..... Now Hold Down Back Key....Now U Got App Management... Select File Manager Open That .....install The Nova Launcher And Open it Then install QuickShortcut Maker...... Now open QuickShortcut Maker Select Google Account... Open That Click on Try Now u Login On Browser...... After Restart Ur Phone ......Set Ur Phone On Welcome....... That's It
Old 11-30-2016, 12:13   #13 (permalink)
Member: 1930738
Sonork: 100.1638397
Thanks Meter: 80
In QuickShortcut Maker
Old 12-04-2016, 08:47   #14 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Port : Fastboot Interface
Baud Rate : Not Applicable
Device : Generic
Operation : Huawei SPD FRP Reset
Searching for Device in FastBoot Mode... OK
Reading Information... OK
FastBoot Ver. : 1.0
Product
Bootloader : Locked
Bootloader is Locked. FRP Reset may fail!
Removing FRP Lock... Done
Operation Finished.
Elapsed Time: 00:14
[Module Ver. 3.3]
Log Saved to Logs\161204_131200.log
Old 12-04-2016, 15:14   #15 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Originally Posted by abishekkumar View Post
Port: Fastboot Interface
Baud Rate: Not Applicable
Device: Generic
Operation: Huawei SPD FRP Reset
FastBoot Ver.: 1.0
Product
Bootloader: Locked
Operation Finished.
Elapsed Time: 00:14
[Module Ver. 3.3]
Hello,
Post in correct forum this is cm2 forum
Sent from my S_plus using Tapatalk
Page generated in 0.22728 seconds with 9 queries
