Old 10-27-2016, 13:20   #1 (permalink)
Member: 1146038
Thanks Meter: 180
Lyf Ls-4006 reset problem ..
Operation : Format File System / Reset Settings [ v1.22 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 75 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC9830 eMMC Generic Loader v2 Inf
Sending FLASH FDL
Boot failed!
Boot failed!
Reconnect Power/Cable!
Old 10-27-2016, 14:04   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,065
Hello. Does it on SC9830? If yes - tick "AltLDR" option and repeat operation.
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-28-2016, 17:39   #3 (permalink)
msmobile's Avatar
Member: 253882
Sonork: 100.1585698
Thanks Meter: 238
just select SC9830 emmc and format fs
Phone found! [ 27 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:22
Old 01-30-2017, 21:03   #4 (permalink)
Member: 2601459
Thanks Meter: 7
Model flame 7 ls 4006
Problem touch not work at bottom line (menu)
Other side working fine i change touch but not solved
After i flash with miracle readed file but touch pad
Properly not working
When i try to flash with pac file original tool NV failed
And miracle error id 123
My set stuck at welcome screen because touch not working
Page generated in 0.21151 seconds with 7 queries
