Old 05-05-2016, 08:35   #1 (permalink)
Member: 2397029
Thanks Meter: 52
LG D331 firmware needed
Need original LG-D331 firmware.Any one have this phone please help read firmware CM2 & post here............
Read info
Operation : Check / Read Info [ v1.47 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 1501005137585341420B58FBE6E6C11F
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BASX7
[eMMC] : FLASH_CID : 1501005137585341420B58FBE6E6C11F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 1B1CF4501C8AF79521A5604581E67C6A
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : lge
ProdName : luv80ss_global_com
ProdModel : LG-D331
Device : luv80ss
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.W10.24.p0
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_SP_V11_P2_1_w g_n
Done!
Elapsed: 00:00:07
Reconnect Power/Cable!
Old 05-05-2016, 09:05   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Can you make "NVRAM read" and upload result log here? It will help me alot.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-05-2016, 09:27   #3 (permalink)
Member: 2397029
Thanks Meter: 52
NVRAM here
MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_SP_V11_P2_1_w g_n_eMMC - Download - 4shared
The Following User Says Thank You to gsmmobile.bgd For This Useful Post:
Old 05-05-2016, 09:30   #4 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by gsmmobile.bgd View Post
Thanks, also need log of nmv reading.
There must be also read sec file. It need for adding that model completely in next CM2MTK updates.
Old 05-04-2017, 15:39   #5 (permalink)
AgicAga's Avatar
Member: 866455
Sonork: SAMSUNG CPID ONLINE
Thanks Meter: 579
FIRMWARE nead help urgent thnx
Old 05-04-2017, 15:54   #6 (permalink)
JayDi's Avatar
Member: 462970
Try use LGS module, kdz can be found over google for a few seconds.
Page generated in 0.16989 seconds with 8 queries
