11-10-2015, 09:06 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: GsmHosting
Member: 1748667 Status: Offline Sonork: 100.1602468 Thanks Meter: 108 | m activated today only cm2 dogle in my new infinity 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 55 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x3 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
11-10-2015, 09:11 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, MT6592 supported- http://forum.gsmhosting.com/vbb/f296...-done-2011000/. Try to connect phone without pressing any keys. Which phone model is this? |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
11-10-2015, 09:14 | #3 (permalink) | |
Member: 1748667 Status: Offline Sonork: 100.1602468 Thanks Meter: 108 | Quote:
this is panasonic moibile model no: p81 | |
11-10-2015, 13:06 | #6 (permalink) | |
m trying to format but same error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! | |
11-10-2015, 14:33 | #7 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | install latest MTK drive or hold vol _ key or use Combo boot cable and solve your problem |
The Following User Says Thank You to rafi_5217705 For This Useful Post: |
11-10-2015, 17:02 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | And first one and matter - select correct CPU. Hard to make mistake, because there is just 3 option. |
