01-16-2017, 09:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | m95 hang on logo plz help FW Size : 1335 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : scx35_sp7731gea Device CPU : sp7731gea Device IntName : scx35_sp7731geaplus_dt Device Version : 4.4.3 Device Compile : 7/31/2015 12:00:38 PM Device Project : KOT49H 14B_test-keys Device ExtInfo : QMobile M95 Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 52 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:04:10 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 52 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! UserData : PART_MOUNT failed! Part Damaged! Will use Repair Mode! Cache : PART_MOUNT failed! Part Damaged! Will use Repair Mode! Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
01-17-2017, 10:29 | #5 (permalink) |
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | its flash ic dameg Operation : FlashIC ReadOnly/BadBlock Test [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 54 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Error on FlashVerification! Seems as FlashIC is faulty! Finalize Ok! Test NOT PASSED! FlashIc is DAMAGED/BAD! Elapsed: 00:00:14 Reconnect Power/Cable! |
