10-25-2017, 17:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | M95 Imie null detail information as under plz infinity help hardware sc8830 andriod version 4.4.3 software version qmobile_m95_mp_03_07 kernel version 3.4.5 first the mobile did not deduct spd drivers.and show in device manager so many spectrum drivers in yellow.and connect with cm2.i connect it with miracle box .there imei write done.but when check in phone imie is show Null.infinity team plz help me out |
10-26-2017, 11:26 | #3 (permalink) | |
No Life Poster Join Date: Mar 2013
Member: 1892312 Status: Offline Sonork: 100.1651296 Thanks Meter: 76 | flash with good firmware , select update nvram problem solve Quote:
The Following User Says Thank You to Zubair45ali For This Useful Post: |
10-27-2017, 04:13 | #4 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | m95 dead after flashed it i flashed with m95 CSTool_spd_7731_EMMC_SE2_QMobile M95_Android4.4.3_KOT49H 14B_test-keys_20160815_214426.now with this file mobile is dead.if and one have m95 SC8830 flash file.please give me link |
10-27-2017, 10:47 | #5 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | after flashing m95 on white screen m95 flashing log.if any one have ok file plz give me link 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x15 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : SPLLOADER Current File : splloader Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : UBOOT Current File : uboot Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SYSTEM Current File : system Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : USERDATA Current File : userdata Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : CACHE Current File : cache Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : MISC Current Part : misc [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : WMODEM Current File : wmodem Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : WDSP Current File : wdsp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : WRUNTIMENV1 Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : WCNRUNTIMENV1 Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : WCNMODEM Current File : wcnmodem Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : LOGO Current File : logo Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FBOOTLOGO Current File : fbootlogo Flashing now ... [FlashProc] : Ok! Elapsed: 00:03:22 Reconnect Power/Cable! Finish at : [10/27/2017 / 2:42:31 AM] |
10-27-2017, 12:58 | #6 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | with another file m95 hang on q mobile logo Loading : M95 v1 by Nasir Mobiles.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : M95 v1 by Nasir Mobiles FastCheck : 0x00537684CD Loading files ... File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin File : SC77xx.xml Load Ok! |
10-27-2017, 15:39 | #7 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | erased flash chip and again flashed erased flash chip and again flashed.and restore mobile .now mobile is ok and imie is also ok thanks to all those who help me out success log as under ======= Flash Files set for flashing : [ MCU ] : M95 v1 by Nasir Mobiles.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : M95 v1 by Nasir Mobiles File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : wfixnv1 [FlashProc] : Ok! [FlashProc] : NVM Update Current ID : NV_WCN Current Part : wcnfixnv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : sc7731g_CP0_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_Gx.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : fblogo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:06:26 Reconnect Power/Cable! Finish at : [10/27/2017 / 7:23:54 AM] Last edited by pakmobiles; 10-27-2017 at 15:44. |
10-27-2017, 17:26 | #8 (permalink) | |
Member: 1892312 Status: Offline Sonork: 100.1651296 Thanks Meter: 76 | tasted file Quote:
try this | |
