10-01-2016, 14:57 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | Mac x2 [clone copy phone ] imei issue plz help mr jaidi WHEN NO NETWORK , LOG SHOW IMEI WRITE SUCESSFUL . BUT WHEN UNIT GET COMPLETE POWER ON ,UNIT GET REBOOT FOR SECOND & WHEN WE CHECK IMEI IT WILL BE SAME AS OLD IMEI , IMEI IS NOT GETTING CHANGE PLZ HELP READ INFO Card found : S/N : 914EDBBC , v0132 Chinese Miracle II [MTK module] v 1.56 Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : A80111303546484D4210000016D26309 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xA8 , OEM : 0111 [eMMC] : FLASH_INF : [NOT_IN_BASE] , BMHF5 [eMMC] : FLASH_CID : A80111303546484D4210000016D26309 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000001BB000000 [eMMC] : FLASH_UCP : 7088 MiB [eMMC 8 GiB] DEV RID : 0xE918EFAE12518B843AC20F4521F9B70D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : enet ProdName : full_w825_644_ax_xzx_x1_enet ProdModel : MacX2 Device : w825_644_ax_xzx_x1_enet AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : w825_644_ax_xzx_x1_enet_v1.5 SECURITY : IMEI_SW [1] : 355070101937237 IMEI_SW [2] : 355070101937245 BTMAC Addr : 0000468B9928 WiFi MAC : 886CF27A02C8 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P3_1_wg_n EXTRA : LCD [0] : otm9605a_qhd_dsi_vdo_boe_w825_xzx_x18 LCD Res : 960x540 TOUCH [0] : focaltech_new CAM [0] : ov9762_mipi_raw CAM [1] : gc5005mipi_raw ov9760_mipi_raw ov9760_mipi_raw_back MODEM : w825_band1_band5_co_gps LOCALE : en_US th_TH zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:16 Reconnect Power/Cable! IMEI WRITE LOGS Operation : Repair Security [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : A80111303546484D4210000016D26309 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xA8 , OEM : 0111 [eMMC] : FLASH_INF : [NOT_IN_BASE] , BMHF5 [eMMC] : FLASH_CID : A80111303546484D4210000016D26309 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000001BB000000 [eMMC] : FLASH_UCP : 7088 MiB [eMMC 8 GiB] DEV RID : 0xE918EFAE12518B843AC20F4521F9B70D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 355070101937237 IMEI [01] : 355070101937245 IMEI [02] : 861622010000056 IMEI [03] : 861622010000056 Set IMEI [00] : 355070101937245 Set IMEI [01] : 355070101937252 Prepare finished. Security check required! Wait for phone... Phone found! [ 21 ] Sync... Repair done! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
10-01-2016, 15:41 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Make "FW Read" operation. Take from FW folder 3 files : scatter.txt preloader.bin and nvram.bin ( extra files folder ) Zip those 3 files and send me link in PM. |
10-03-2016, 14:03 | #7 (permalink) | |
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | Quote:
Repair security is in permenant mode only dear The problem is after sucessful repair security done imei Will b applied successfully , but when you insert SIM card & switch on the unit after complete power on , when it connect To the network suddenly it reboot for a second & imei will b The same as before old imei only , nothing change will b done | |
