01-26-2015, 08:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: in this world
Member: 292087 Status: Offline Sonork: 1575183 Thanks Meter: 194 | I reset privacy lock bt still there 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 273 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A177DA51D5 DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 271 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A177DA51D5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A177DA51D5 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... #4 : Data CRC Error : F6C7 , 0BAE Privacy Lock not set! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
01-26-2015, 08:54 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. It not finished due some problems with data exchange. Way to fix : Clean ALL com ports ( check for some SW, like DC-unlocker for clean ) Insert cable in other port and try again. Also : Use port on motherboard directly , instead hubs and e.t.c.. Not use any other software running, which can take/eat much system resources. Probably - better re-install drivers (inside CM2 folder) If still same - use other PC. You can have much problems with phones, until not fix your system. |
