10-03-2007, 17:20 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 577020 Status: Offline Thanks Meter: 27 | maini SET ON ONLY 10 SEC. Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: 20F1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 0020:00F10080001D [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 921600 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw2: MAUI.05C.W06.24.MP.V18 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [standard] (or higher) generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done Finished, time used: 48 sec Remove/Install battery now ! ANY SOLUTION INFINITY MASTERS |
10-04-2007, 08:44 | #3 (permalink) |
Member: 577020 Status: Offline Thanks Meter: 27 | maini i will try safe mode but answer Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 27 sec Remove/Install battery now ! |
10-04-2007, 09:13 | #5 (permalink) |
Freak Poster Join Date: Sep 2006 Location: syria damascus
Member: 348451 Status: Offline Thanks Meter: 2 | when you use the safe format mode you have to keep pressing the power button untill the phone start powering up then the softare will tell you to remove your hand |
10-04-2007, 10:56 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
10-07-2007, 09:36 | #11 (permalink) | |
send backup file to [email protected] also include in your mail information about phone connector and pinout. We will check your backup and then we will see what to do. | |
10-15-2007, 15:26 | #15 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | A818 Gaoxinqi Set Restart Ok A818 Model phone name GAOXINQI Resatart problem with sim.I read full back up and formate ''safe' condition and setting side 6288 NAND type selected.Pin out keyboard up side 1.......8,1 gnd,2rx,3tx.now working with sim.For first time set get long time to ON.See log. Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.56 S/N: xxxxxxxxx Wait... Device: Autodetect 6205-6227 NOR Done Device: Autodetect 6228 NAND WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... COM3 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: MAUI.05C.W06.24.MP.V18 Version: MT6228_05C_HW detecting structure #2... done imei: 35081800319882 warning: wrong packet checksum warning: wrong packet checksum 230 of 235 items cleared 3 items remains Finished, time used: 54 sec Remove/Install battery now ! |
maini | veerpreet | Nokia Hardware & Hardware Repair | 4 | 06-16-2008 07:49 |
maini | veerpreet | Infinity-Box | 1 | 05-30-2008 14:29 |
Maini | veerpreet | Universalbox | 0 | 05-26-2008 18:40 |
maini | veerpreet | Nokia Hardware & Hardware Repair | 0 | 05-13-2008 09:17 |
