06-12-2018, 14:38
#1 (permalink)
Member: 2501288
Thanks Meter: 328 | MAJESTIC tab 527 3g 7731g failed hi
i tired to boot tab 527 3g 7731g with all mode but always failed Quote:
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
Start at : [12/6/2018 / 13:11:38]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 89 ]
Port Opened
Sync...
Initial Boot Failed!
Boot not done, reason : Wrong BootKeys
Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down )
Reconnect Power/Cable!
Finish at : [12/6/2018 / 13:11:43]
Start at : [12/6/2018 / 13:11:51]
3. Insert cable
Phone found! [ 89 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Finish at : [12/6/2018 / 13:12:02]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x]
Start at : [12/6/2018 / 13:12:21]
3. Insert cable
Phone found! [ 89 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Finish at : [12/6/2018 / 13:13:29]
Start at : [12/6/2018 / 13:25:38]
3. Insert cable
Device boot not done
Check Drivers
Try again
Finish at : [12/6/2018 / 13:25:41]
Set mode to : [AltLDR] SP [SC773x] eMMC [Generic 4.x-5.0]
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Start at : [12/6/2018 / 13:28:22]
3. Insert cable
Phone found! [ 89 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/6/2018 / 13:31:21]
Start at : [12/6/2018 / 13:32:25]
3. Insert cable
Phone found! [ 89 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/6/2018 / 13:32:54]
Start at : [12/6/2018 / 13:34:23]
3. Insert cable
Phone found! [ 89 ]
Open Port Failed!
Finish at : [12/6/2018 / 13:34:23]
Start at : [12/6/2018 / 13:34:29]
3. Insert cable
Phone found! [ 89 ]
Port Opened
Sync...
Sync...
Sending FDL
