03-16-2008, 15:43 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Device unlocker
Member: 135532 Status: Offline Thanks Meter: 17 | all mtk 6205 all of us have problem when formatting mtk 6205 chip cause when we press power to connect the phone and relese it the boot stop and when we prees long time the phone will power and complete the format but nothing happend in the phone so we want to fix this problem i have alot of phone with mtk6205 thank you b.r. |
03-16-2008, 15:52 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Please, explain th problem little bit detailed, post logs here. I can't understand what is the problem because I never have seen any problems with old phones based on MT6205 CPU. |
03-17-2008, 06:43 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2005 Location: Iclouds
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | i want to formate sands a303i .cpu is 6205 here is operation log COM5 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: wrong answer[2A] error: no any expected answer: wrong answer after chip id request error: wrong answer[3B] error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 30 sec Remove/Install battery now ! b(.)(.)r mobilecraker |
03-17-2008, 10:16 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! do you know that 6205 is second MCU (MCU_b) why you need to format it? how do you boot it? via pressing button or via setting to GND power_b test point? |
03-17-2008, 10:54 | #7 (permalink) | |
Member: 142219 Status: Offline Sonork: 100.107814, Thanks Meter: 368 | Quote:
1.cpu is mt 6226 2. i need to formate this one bcoz with sim its getting restart 3.i m using vepro box for dection if the steps are wrong then please guide me with right procedure thanx mobiecraker | |
iffco a76 MTK 6205 cpu | shashankmobile | ET-BoX | 0 | 04-26-2009 10:21 |
need help for mtk 6205 | ironfever2002 | Chinese Models & Cloned Phones | 1 | 08-16-2008 08:37 |
Mtk-6205 Cpu_tecno-t880_restart | baraka42 | Chinese Models & Cloned Phones | 0 | 03-18-2008 15:36 |
