Old 05-08-2009, 23:42   #1 (permalink)
Member: 6142
Sonork: i dont use it
Thanks Meter: 47
Mandarina duck MD02 hungarian flash is corrupt!
Hi!
Please check this flashfile because after flash the phone with this flashfile , phone not turn on!
If i flash with other file from support, phone is ok!
Old 05-09-2009, 07:31   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Originally Posted by roniri View Post
Hi!
did u make repair security when was phone was in dead condition
Old 05-09-2009, 12:34   #3 (permalink)
Member: 6142
Thanks Meter: 47
I tryd to repair security area, but not help! If i flash the phone with other flash from support, phone turn on ! I attach the log about flashing !
==== log: [5/9/2009 12:35:26 PM] ====
COM8 [VCP0] selected
module v2.73
Device: Alcatel-Mandarina-Duck-MD01, MD02
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A03:8A02]...
CPU: MT6226
chip: 0031:C70C:A000
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22302200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: D:\Program
Files\InfinityBox\MModule\backup_security\id.1F2CA F57.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_
SP1_V24.BIN_E5797CF9].rpl
identification#1 detection finished
device-id: 1F2CAF57
identification#1 protocol ver: 05
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V24, 0683861A
ffs offset/size: 01000000/01000000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 357195020XXXXXX
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
file saved: D:\Program
Files\InfinityBox\MModule\backup_security\Alcatel-Mandarina-Duck-MD01,MD02_JRD26_06A_PCB01_GPRS_MT6226_
S02.MAUI_06A_W06_52_SP1_V24__system_log_1F2CAF57_E 5797CF9_20090509-123612.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CC19FV21
error: can't calculate security area (code #3, part #2), existing data will be used
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................counter: 01
security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
Finalization Done
S02.MAUI_06A_W06_52_SP1_V24__system_log_1F2CAF57_E 5797CF9_20090509-123724.B0X.bin
Finished, time used: 103 sec
Remove/Install battery now !
I found, that there is an error, while calculate security area , so i think ,that is the problem!!
Old 05-10-2009, 16:38   #4 (permalink)
Member: 6142
Thanks Meter: 47
Hi!
Flashing phone with new version of Mmodule now phone is working with hungarian flashfile too. Unfortunately this file is simlocked . I have already sent flashbackup from unlocked hungarian mandarinaduck, can you convert for using ?
Thanks, regards Roniri
Old 05-12-2009, 21:01   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi!
Hello,
I think your file was already uploaded in support area, but I think that it was backup from phone that was not originally simfree. Backup from phone that was unlocked by code can not be used to prepare simfree file.
Mandarina Duck MD02 Unlock Problem. Phone Stock Infinity-Box 2 11-30-2009 14:51
K800 flash is corrupt ?? proton DreamBox 3 08-24-2009 18:42
Mandarina duck MD02 problem Johnybye FuriousGold 8 07-25-2009 08:30
Mandarina duck unlock is work great by new update! roniri Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 05-13-2009 00:27
E810 full flash is corrupted in support site? Burnt Cobba NSPRO 1 02-15-2007 05:23
Page generated in 0.16606 seconds with 9 queries
