Old 06-24-2016, 14:42   #1 (permalink)
Member: 946381
Thanks Meter: 139
many htc 616 dead r coming-all r flashing error-help
dead-flashing error as below
catter Load Ok , BaseBand : MT6592 , Project : wt98518 , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.51 ]
======= Flash
Wait for phone...
Phone found! [ 109 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048603A4D9D29179
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048603A4D9D29179
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x76D4059608525682DBB041B843D46056
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3557 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x00000000A9F00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98518.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:58
Reconnect Power/Cable!
i think it emmc problem-am i right?
Old 06-24-2016, 14:46   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,512
Hello.
If you try as SW advise , and sure about FS is correct - then yes, it is eMMC fault.
Old 06-25-2016, 03:24   #3 (permalink)
Member: 946381
Thanks Meter: 139
Originally Posted by JayDi View Post
Hello.
did not understand the meaning of """"""""""""sure about FS is correct """"then yes emmc fault
emmc reball help this error?
Page generated in 0.20988 seconds with 7 queries
