03-10-2010, 20:24 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
04-21-2010, 15:30 | #7 (permalink) |
No Life Poster Join Date: Feb 2009 Location: INDIA
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | please infinity support i need your help i have MAXX MX463 phone , this phone starts shows maxx on display (making sound also)goes on insert sim 1 & 2 but after this we can see display light goes off slowly then this is like a dead phone , no keypad operating no on /off key working then we need to remove battery and start again by on /off key but the same happening again for this i formatted phone in safe & complete mode but not working for this phone remains same so i need flash file for this phone or which one file i have to use from infinity support this is mt 6225 cpu Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: TC63_VER_01_00_HW Software version: TC63B_INDIA_CC_17" Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 357415031897498 imei-2: 357415031897506 imei-3: 357415031897498 Finished, time used: 5 sec Remove/Install battery now ! |
04-22-2010, 06:56 | #9 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | thank you SIR INFINITYHELP for your reply Code: COM7 [VCP1] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4F03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: TC63B_INDIA_UCT25_TC63B_INDIA_PCB01_GPRS_MT6225_S00.TC63B_INDIA_CC_17.BIN project-id: TC63B_INDIA_CC_17, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ....................... detect standard ffs/eeprom location pass #1... ........................................... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: TC63B_INDIA_UCT25_TC63B_INDIA_PCB01_GPRS_MT6225_S00.TC63B_INDIA_CC detecting firmware build... ........................................... firmware build: ,¥"GEMINITC63B_INDIA_CC_17TC63_VER_01_00_HW2009-10-2216-36 detecting product-id... ................................................................ done detecting languages... ...................................... language parameters detected detected languages: En Hi Finished, time used: 1 min 20 sec Remove/Install battery now ! |
04-22-2010, 21:27 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here is your flash file: flashfiles/ChineseMiracle/_MT6225/TC63B_INDIA_UCT25_TC63B_INDIA_PCB01_GPRS_MT6225_S0 0.TC63B_INDIA_CC_17__MAXX-MX463_16m_En_Hi.B0M.bin before flashing i would advice to make full backup of your existing firmware for emergency case |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
04-23-2010, 08:03 | #11 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | thank you SIR INFINITYHELP, i downloaded that file everything is ok but phone is now also as before so now i think this may of hardware issue what is your advice?? |
Maxx mx463 keypad problem | rockindheeraj | Various | 5 | 01-13-2011 10:04 |
Unlocking Motorola V6 Maxx | tunjay-gsm | Motorola P2k | 4 | 03-13-2007 06:19 |
Motorola Razr Maxx V6 Flash Files?? | hello123abchell | Motorola P2k | 0 | 12-19-2006 10:55 |
Motorola Razr Maxx V6 Flash Files?? | hello123abchell | Motorola P2k | 0 | 12-19-2006 10:45 |
Come On Motorola Team Too Slow For V6 Maxx Unlock | tunjay-gsm | Motorola ODM | 1 | 12-11-2006 19:55 |
