01-17-2015, 09:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | [MediaTek] MT6571_S00 security pass i want to dissable why me always break the rules of infinity box section sory for that its just for learning not comparing http://forum.gsmhosting.com/vbb/f715.../#post10794704 i want work work ...................... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:00:10 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Checking data ... Error read initial info , unsupported or erased flash Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
01-17-2015, 09:31 | #3 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
01-17-2015, 09:31 | #4 (permalink) |
01-17-2015, 09:41 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. It not initialize FlashIc by some reason. Try use boot key ( vol up or vol down ) to force RAM init. This flash IC should be in FlashInit database. |
01-17-2015, 09:51 | #6 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Quote:
can i use this for this ?? if u say me dissamble it and use kool and nolo points ???? ues me press vol up and try vol down and try both leave and try result same | |
01-17-2015, 13:23 | #8 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | in device manager show logs........ Quote:
after all 100%................... NAND : Detecting structure now... Please, wait. NAND : Structure detect failed! Send report to support! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:05:38 Reconnect Power/Cable! | |
01-18-2015, 12:14 | #12 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | hi hi hi ...................... i try in nand option p1 than try p2 p3 try but not success may be its bootloader lock 3d party also launch mtk bootloader unlock with this also not success where me not follow u need screen shot ................ |
01-18-2015, 12:22 | #13 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Here : http://forum.gsmhosting.com/vbb/10804439-post8.html Only once I've seen success boot. Need same + P1/P2/P3 param. And it WILL work. |
