01-28-2015, 16:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | MediaTek MT6582 question Chinese Miracle II [MTK module] v 1.10 Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:44 Reconnect Power/Cable! Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:49 Reconnect Power/Cable! |
01-28-2015, 16:59 | #3 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | now other select OK Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E5030585858581096DAE54E51FB DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : XXXX0 [eMMC] : FLASH_CID : FE014E5030585858581096DAE54E51FB [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! |
