03-08-2016, 18:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Online Sonork: Double Kanon Thanks Meter: 2,654 | [MediaTek] MT6735 Code: Operation : Repair Security [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 613 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 353446071220089 failed , record not exist or NVRAM damaged! Update IMEI[2] to : 353446075720084 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:05:34 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 613 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332383F4D0042C92184EC Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42004D3FEC84B2C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : A42D39C36A72E9426B22E3B97FA28BB1 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 353446071220089 IMEI [01] : 353446075720084 Set IMEI [00] : 353446071220089 Set IMEI [01] : 353446075720084 Prepare finished. Security check required! Wait for phone... Phone found! [ 613 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just reinsert cable) on this step Reconnect Power/Cable! is there newest drivers for this cpu to repair emei |
The Following User Says Thank You to MDK23 For This Useful Post: |
04-01-2016, 20:47 | #8 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Zanzibar Tanzania
Member: 1091079 Status: Offline Thanks Meter: 13 | bplguinfocustomappsrcp_mt6735 PLZ HELP THIS FILE FOR REPAIR IMEI Quote:
04-01-2016, 23:08 | #9 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, @nyokafey Here It's Database Of MT6735 : DOWNLOAD Why Are You Ignore Posts Number #2 & #5 Of Currently Thread ? If Really You Don't Know. How To Get Device VID/PID So Read Some Posts Please. (1) http://forum.gsmhosting.com/vbb/11510803-post4.html (2) http://forum.gsmhosting.com/vbb/11691400-post3.html (3) http://forum.gsmhosting.com/vbb/11612585-post4.html (4) http://forum.gsmhosting.com/vbb/11356519-post10.html |
The Following User Says Thank You to MyGSM World For This Useful Post: |
