04-18-2017, 02:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Tonga
Member: 2422331 Status: Offline Thanks Meter: 41 | MediaTek MT6737M|MT6737_S00 Unlock Help Code: Card found : S/N : XXXXXXXX , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 179 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following User Says Thank You to ChElEuLaVi For This Useful Post: |
04-18-2017, 08:26 | #2 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Which model is this? Anyways not supported for now- Quote:
Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
08-26-2017, 14:41 | #4 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Optus 5080Q unlock problem Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! I have same problem with same model |
The Following User Says Thank You to Arafat Mashaka For This Useful Post: |
08-27-2017, 06:20 | #5 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 652762 Status: Offline Thanks Meter: 16 | Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following User Says Thank You to .manoj. For This Useful Post: |
08-27-2017, 06:44 | #6 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1087456 Status: Offline Thanks Meter: 39 | Quote:
Same Problem Symphony P9 FRP Please Team Solution Quickly | |
The Following User Says Thank You to mijanur_017 For This Useful Post: |
08-27-2017, 07:51 | #7 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2738731 Status: Offline Thanks Meter: 0 | oppo 1201 not flash not unlock not boot unlock Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100463331324D420621959BAB63C9 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:35 Reconnect Power/Cable! |
